MailEnable SMTP server is not accessible: The host was either not contactable or it rejected your connection
Created:
2016-11-16 12:48:41 UTC
Modified:
2017-08-18 19:59:21 UTC
Have more questions?
Submit a request
  • Plesk for Windows
  1. Mails are not getting delivered from the server and got stuck in the outbound queue with the error:
    Communications Error: Socket connection to alt4.gmail-smtp-in.l.google.com failed (error 10013). The host was either not contactable or it rejected your connection. Socket Family = 23; Host=1234:f8b0:400c:c03::1abcd; Port=25
  2. It may be not possible to connect locally to SMTP port while service is running properly:
    C:\> telnet 127.0.0.1 25
    Connecting To 127.0.0.1...Could not open connection to the host, on port 25: Connect failed
  3. Antivirus software is installed on the server.
Antivirus blocks connections to 127.0.0.1.
Configure corresponding exceptions in antivirus or remove it.
