Panel shows wrong control links "[[activePanelSessions]]" and "[[activeFtpSessions]]"
Created:
2016-11-16 12:48:05 UTC
Modified:
2017-08-16 17:00:41 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
Within the ' Tools & Settings ' screen in our Panel, there are some odd display values:
"[[admin.controllers.server.tools.securityPanel]]", which includes the
options "[[activePanelSessions]]" and "[[activeFtpSessions]]".
The file ' /usr/local/psa/admin/panel/application/resources/languages/en-US/controllers/server/Tools.php ' realted to Plesk Core Package was corrupted.
Replace the corrupted file with valid one from repository package. To perform this please follow the steps bellow:
  1. Make sure that ' Tools.php ' file was not replaced by insalling MU. Open ' /tmp/autoinstaller3.log ' file an search through with ' Tools.php ', you should have no results found.
  2. Download the ' plesk-core_11.5.30 ' package according to your system in Plesk repository: http://autoinstall.plesk.com/PSA_11.5.30/
  3. Extract the package:
RPM
#rpm2cpio mypackage.rpm | cpio -vid
DEB
First, extract the aforementioned three files from the DEB file (ar archive):
#ar vx mypackage.deb
Second, extract the contents of data.tar.gz using tar:
#tar -xzvf data.tar.gz
  1. Replace your ' Tools.php ' with one from the package:
    cp ./usr/local/psa/admin/panel/application/resources/languages/en-US/controllers/server/Tools.php /usr/local/psa/admin/panel/application/resources/languages/en-US/controllers/server/Tools.php
