If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Plesk Migration and Transfer Guide
20 comments
    Marco Marsala (Edited )
    Beware: Plesk Migrator won't migrate (without notice): MySQL routines, events, triggers, user-specific permissions, event scheduler status.
    -1
    Bulat Tsydenov
    @Marco, I replied in comments for Plesk Migrator Extension. Known limitations article.
    -1
    Unknown User
    When all the post checks are completed and the migrated domains’ data is synchronized with the source server, it is time to turn the services online on the destination server.
    Paykasa - Paykwik - Astropay
    i need this but i cant using my servers destination servers i cant understandt for paykasa. It is running now no problem
    -1
    Ivan Postnikov
    Hello @Paykasa,
    Could you, please, clarify the question?
    The website does not work after migration? If yes, what error is displayed?
    For the investigation consider contacting Technical Support.
    -1
    Iman GM
    Hello there,
    Thank you for your detailed instructions. I have a problem with Plesk migration. It's soooo slow... I wonder if you know that how it works. Does it copy files in a websites one by one or does it make a backup of the whole website and moves it at once to the destination server? If it's moving the web files one by one, isn't it a better idea to make a full backup of each website, then move it to the new server and restore it? Does it help to make the process much faster?
    Thanks!
    -1
    Ivan Postnikov
    Hello @Iman,
    Generally, migration speed depends on many factors: amount of domains, amount of files, files size, network speed.
    You are correct. Basically, Plesk Migrator creates a backup, transfers it, restores the backup.
    -1
    Kiani (Edited )
    Hello there,
    Thank you for your detailed instructions. this instructions is only for Onyx ?
    i can not migrate from cpanel to plesk. plz help me .
    tks.
    -1
    Ivan Postnikov
    Hello Kiani
    Plesk migrator is capable of migrating from cPanel but the same OS is required to be used. So, you may migrate from cPanel to Plesk server on linux.
    To transfer domains from Linux server to Windows you may use "Site Import" extension:
    https://support.plesk.com/hc/en-us/articles/115000383334-How-to-migrate-a-website-from-other-server-to-Plesk-
    -1
    Kea
    when I try to update TTL, I get an error:
    -bash: syntax error near unexpected token `do'
    I use ‪Ubuntu 18.04.3 LTS‬ and Plesk 18.0.21.
    -1
    Anzhelika Khapaknysh
    Hi @Kea,
    I have tested the command on Ubuntu 18.04 with Plesk Obsidian 18.0.21.5 and it works well for me.
    Please make sure that you have used the following command:
    for domain in $(MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -u admin psa -Ns -e"select name from dns_zone where name not in (select val from misc where param = 'FullHostName')") ; do /usr/local/psa/bin/dns --update-soa $domain -soa-ttl 1h; done
    -1
    Kea
    Hi @...,
    Thank you for your response.
    Does this command work with "sudo"?
    -1
    Maxim Krasikov
    Hello @Kea,
    Yes, the command works with "sudo" and should be executed under root user.
    -1
    Mike Homme
    We'd like to migrate from cPanel to Plesk but I see the cPanel version above listed as 11.5. We're running cPanel 11.48.0 (build 12). Are you aware of any migration issues with our version of cPanel?
    -1
    Anton Maslov
    Hello Mike Homme we constantly update tools to support migration from latest cPanel, so you should be able to migrate without issues.
    -1
    Mike Homme
    Anton Maslov
    Thanks very much for the quick reply.
    I'm sure you're updating the tools which is great. But could you verify that cPanel 11.48 (our current version) was/is in any way deprecated for incompatibility reasons for a successful migration? Above it seems cPanel 11.5 is a "requirement"... no?
    -1
    Anton Maslov
    Mike Homme double checked here: officially we test and support migration from latest cPanel version. However with high probability migration from 11.48 will work as there were no major changes so I recommend to try.
    -1
    Mike Homme
    Anton Maslov - Thanks very much for the response. Looking forward to using Plesk!
    -1
    saikat das
    hello sir, i am facing a problem after migrating my websites to 1 plesk server to another plesk server.
    my all domains which i have migrated are not working. i don't know why! my all website files and databse migrated successfully , but my website is not live yet. website link https://socialhost.xyz
    plesk click on the link to see what it is showing .
    can anyone please help me to solve this problem ? please
    1
    Peter Kielbasiewicz (Edited )
    I am running a vServer with Ubuntu and every other year I need to update the opsys and migrate the Plesk configuration.
    When I did this for the first time, I requested a new vServer, installed the new opsys and migrated Plesk with the plesk migrator.
    After that, I needed to transfer my domains (I have 2) too, because of the new IP address. This is an extra step, involves other parties, and causes some delay.
    Thus, I found it much easier to backup plesk using a command like:
    /usr/local/psa/bin/pleskbackup --server -output-file /myBackups/
    Then I do a fresh install on the existing vServer and restore the plesk backup using something like:
    /usr/local/psa/bin/pleskrestore --restore /myBackups/backup_???.tar -level server
    This way I do not need to hassle with domain transfer and everything is directly under my control.
