How does password strength policy work in Plesk?
7 comments
    Anton Maslov
    Hello,
    Unfortunately there is nothing we can suggest based on the provided information. Please create a support request to troubleshoot the issue.
    Ivan Postnikov
    Hello @Peter,
    Thank you for sharing your idea. I have created a feature suggestion.
    The top-rated features will be implemented in next Plesk updates.
    EFTHIMIOS SIDERIS
    Hello,
    OS is: CentOS Linux 8.1.1911
    EFTHIMIOS SIDERIS (Edited )
    Plesk REST API fails to create ftp user with some ftp_password e.g. b&3$0BRldB~1 with message: "Do not use quotes, space and national alphabet characters in a password. The password length should be from 5 to 14 characters in length, and it should not contain the username."
    while there is no problem using the same password through dashboard.
    Am I doing something wrong or is a bug?
    Plesk Obsidian Web Host Edition
    Version 18.0.27
    Renan Genova Ferreira
    Hello, EFTHIMIOS SIDERIS!
    Can you please tell the OS version you have Plesk Installed?
    Thank you
    EFTHIMIOS SIDERIS
    Hello again,
    Nobody can answer?
    Thank you
    Peter Wise
    Please consider implementing Dropbox's password strength library in future versions of plesk. https://github.com/dropbox/zxcvbn
    Right now (Plesk Onyx Version 17.8.11) very secure passwords such as applaud-bisque-batch-forefoot won't even pass the "medium" filter, and very bad passwords such as Pa$$word123 are marked "Strong".
    Brute force cracking continues to get more sophisticated and the current strength ratings are misleading.
