Extensions section is blank
Created:
2016-11-16 12:47:02 UTC
Modified:
2017-08-16 16:21:40 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
  • Plesk 11.x for Windows
Extensions section is blank. No extensions are shown. Buttons also not visible.
This command returns not empty output:
 # /usr/local/psa/bin/extension -l
Orphaned extension record is present in database.
  1. Create backup of psa.Modules table:
      # mysqldump -uadmin -p`cat /etc/psa/.psa.shadow ` psa Modules > plesk_psa_backup_modules.sql
  2. Remove records one-by-one from Modules table checking what record causes the issue.
  3. When orphaned record is found, restore Modules table back and remove that orphaned record again:
      # mysql -uadmin -p`cat /etc/psa/.psa.shadow ` psa < plesk_psa_backup_modules.sql
    mysql> delete from Modules where id=1;
    id 1 is the number of corrupted module in database.
