Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
SFTP is not available for additional FTP users
20 comments
    Permanently Deleted User
    This method seems to work with Plesk 12.x on CentOS 6.5, but not anymore with Onyx on CentOS 7. The user can still logon but is not chrooted, it has acces to the whole vhost!
    Artyom Baranov
    Hello Tim,
    Changing the shell for an additional user to `/usr/libexec/openssh/sftp-server` only grants him the permission to connect over SFTP.
    That does not enable chrooted access and is not officially recommended.
    Maik Vattersen
    Enable SFTP Login like below, let customers Browse the Filesystem.
    They are able to see other Domain and Systemfolders, but are unable to get into these Directories. BUT they can download Configs from /etc and other Paths!
    I didn't find a quick solution, to enable SFTP for Customers with chroot Environment.
    Taras Ermoshin
    Hi @Maik Vattersen !
    In Plesk, chrooted SFTP access is possible only for the subscription's system user.
    Additional FTP users of the subscription have the same UID as the system user, and because of that, the chrooted shell cannot be used for them, but only non-chrooted SFTP as described in this article.
    If you think SSH access for the additional FTP users is to be implemented in Plesk, feel free to create a feature request (or vote for an existing one) on the UserVoice portal. If a request gets many votes, it will be considered for implementing.
    As for not accessing files of other subscriptions and accessing configuration files in /etc and other locations, this behavior is expected - subscription directories have permissions 710 (drwx--x---), and the majority of the /etc subdirectories have the read permission for other users.
    Serverfarm
    that bash script it doesn't work anymore, can you update?
    Pavel Rozental
    Hello Serverfarm,
    Thank you for the notice. Script was updated.
    Digital Sparks Srl
    Hello, this bash script on my server produce only this operation:
    # ./213912005_clone_shell.sh sdm3
    changing sdm3 shell from /sbin/nologin to /bin/false
    After this operation, the test has the same error: Received unexpected end-of-file from SFTP server.
    how can i solve?
    Thanks you all!
  • Hi Digital Sparks Srl,
    Please check first if the main FTP user has chroot shell in Domains > example.com > Web Hosting Access > Access to the server over SSH.
    I've just tested the script and works fine on my CentOS 7.
    Connection to example.com... Please wait.
    Connected to example.com.
    Starting SSH authentication...
    Trying SSH authentication GSSAPI_WITH_MIC...
    SSH GSSAPI_WITH_MIC authentication failed.
    SSH PUBLICKEY authentication failed.
    SSH PUBLICKEYAGENT authentication failed.
    Trying SSH authentication PASSWORD...
    SSH authentication success!
    SFTP connection started.
    SFTP session started!
    Opening directory /...
    Open directory command received
    Directory content listed
    Digital Sparks Srl
    Hi, thanks! Now works but the user view ALL directory...Is possible to limit access to the only folder assigned?
    Just put a directory home which is not /, for example: /httpdocs. The user with home /httpdocs won't be able to get on / or /logs, only /httpdocs/WhateverHere.
    Additional info here.
    Digital Sparks Srl
    Hi Francisco, I did this procedure, inserting the directory (example "partecip").
    But from filezilla client the user can also navigate in other folders of the same level and / or previous ones. I would like to limit to the only and exclusive folder "partecip"
    Thanks for your consideration
    Then, please open a support request here, so that it's investigated properly since I couldn't reproduce the behavior you describe in my test env.
    ignacio correia
    You need to mention that the service needs to be restarted don't you?
    Yulia Plokhotnikova
    @ignacio correia,
    The script does not actually make configuration changes in the SFTP service. What it does is changing shell for a user with 'usermod -s' command that does not require any service restart.
    1
    ignacio correia
    I need to do this to all users FTPS? I have increased access to SFTP only. could this bug please be considered as a priority to be fixed?
    Ivan Postnikov
    Hello ignacio correia,
    If you'll be able to specify all FTP users while the 1st run of the script that would be sufficient.
    As SFTP protocol is different from FTP(S) this is considered as a new functionality to be added. Feel free to vote for this functionality. Top-rated suggestions are implemented faster.
    Michael M. (Edited )
    Hi guys,
    i try to set up SFTP SFTP Backup Accuount but get
    Error: Failed to list the directory "/" at sftp://domain.com: cURL error (1): Protocol "sftp" not supported or disabled in libcurl
    Search for related Knowledge Base articles
    Search Link aims me to empty page.
    So what do i do in this case?
    Robert Asilbekov
    @Michael M. SFTP Backup extension does not work on Plesk with Ubuntu 16 and 18 as well as with Debian 8 and 9. As Plesk is using Curl package that shipped by your OS vendor. So, please ensure that you have curl version with sftp support.
    Michael M.
    @Robert Asilbekov
    Thanks!
    Sо it there a way to add a curl with SFTP support to these OS? Maybe install it additionally, but how? I'am bun in Linux...
    Robert Asilbekov
    @Michael M. It is better to do a dist upgrade on your "deb" OS. You may refer to the article How to perform dist-upgrade procedure on Linux server with Plesk?
