Additional FTP user is specified instead of the subscription's system user
SFTP connection cannot be established with the similar error on connection attempt:
# sftp additional_user@203.0.113.2
additional_user@203.0.113.2's password:
Connection closed# sftp additional_user@203.0.113.2
unexpected end of fileNote: SFTP stands for SSH File Transfer Protocol and uses SSH for establishing connection and transferring the data.
FTP and FTPS connections are not affected by this issue, as they use the different protocol and mechanisms. -
Similar errors might be logged by the Journal:
# journalctl --since="10m ago" | grep chrootsh
plesk-chrootsh[16727]: user with id=10000 and name=additional_user not found in chrooted passwd file
plesk-chrootsh[16727]: system error: No such file or directory
SFTP configuration for additional FTP users is not implemented in Plesk yet.
Vote for this feature on our UserVoice portal.
Warning: Such configuration was not officially tested. It might be changed automatically in case users are modified through Plesk.
Shell value of the additional user will not be synchronized with the main user.
Download and unpack the script:
# curl -LO https://plesk.zendesk.com/hc/article_attachments/360009752840/213912005_clone_shell.tar.gz
# tar xf 213912005_clone_shell.tar.gz -
Run the script providing the names of additional users:
# ./213912005_clone_shell.sh examplecom1 examplecom2
Changing examplecom1 shell from /bin/false to /usr/local/psa/bin/chrootsh
Adding examplecom1 to the chrooted passwd file
Changing examplecom2 shell from /bin/false to /usr/local/psa/bin/chrootsh
Adding examplecom2 to the chrooted passwd fileNote: The additional user should have access to the
directory in Plesk under Domains > FTP Access > additional_user
16 comments
This method seems to work with Plesk 12.x on CentOS 6.5, but not anymore with Onyx on CentOS 7. The user can still logon but is not chrooted, it has acces to the whole vhost!
Hello Tim,
Changing the shell for an additional user to `/usr/libexec/openssh/sftp-server` only grants him the permission to connect over SFTP.
That does not enable chrooted access and is not officially recommended.
Enable SFTP Login like below, let customers Browse the Filesystem.
They are able to see other Domain and Systemfolders, but are unable to get into these Directories. BUT they can download Configs from /etc and other Paths!
I didn't find a quick solution, to enable SFTP for Customers with chroot Environment.
Hi @Maik Vattersen !
In Plesk, chrooted SFTP access is possible only for the subscription's system user.
Additional FTP users of the subscription have the same UID as the system user, and because of that, the chrooted shell cannot be used for them, but only non-chrooted SFTP as described in this article.
If you think SSH access for the additional FTP users is to be implemented in Plesk, feel free to create a feature request (or vote for an existing one) on the UserVoice portal. If a request gets many votes, it will be considered for implementing.
As for not accessing files of other subscriptions and accessing configuration files in /etc and other locations, this behavior is expected - subscription directories have permissions 710 (drwx--x---), and the majority of the /etc subdirectories have the read permission for other users.
that bash script it doesn't work anymore, can you update?
Hello Serverfarm,
Thank you for the notice. Script was updated.
Hello, this bash script on my server produce only this operation:
# ./213912005_clone_shell.sh sdm3
changing sdm3 shell from /sbin/nologin to /bin/false
After this operation, the test has the same error: Received unexpected end-of-file from SFTP server.
how can i solve?
Thanks you all!
Hi Digital Sparks Srl,
Please check first if the main FTP user has chroot shell in Domains > example.com > Web Hosting Access > Access to the server over SSH.
I've just tested the script and works fine on my CentOS 7.
Connection to example.com... Please wait.
Connected to example.com.
Starting SSH authentication...
Trying SSH authentication GSSAPI_WITH_MIC...
SSH GSSAPI_WITH_MIC authentication failed.
SSH PUBLICKEY authentication failed.
SSH PUBLICKEYAGENT authentication failed.
Trying SSH authentication PASSWORD...
SSH authentication success!
SFTP connection started.
SFTP session started!
Opening directory /...
Open directory command received
Directory content listed
Hi, thanks! Now works but the user view ALL directory...Is possible to limit access to the only folder assigned?
Just put a directory home which is not /, for example: /httpdocs. The user with home /httpdocs won't be able to get on / or /logs, only /httpdocs/WhateverHere.
Additional info here.
Hi Francisco, I did this procedure, inserting the directory (example "partecip").
But from filezilla client the user can also navigate in other folders of the same level and / or previous ones. I would like to limit to the only and exclusive folder "partecip"
Thanks for your consideration
Then, please open a support request here, so that it's investigated properly since I couldn't reproduce the behavior you describe in my test env.
You need to mention that the service needs to be restarted don't you?
@ignacio correia,
The script does not actually make configuration changes in the SFTP service. What it does is changing shell for a user with 'usermod -s' command that does not require any service restart.
I need to do this to all users FTPS? I have increased access to SFTP only. could this bug please be considered as a priority to be fixed?
Hello ignacio correia,
If you'll be able to specify all FTP users while the 1st run of the script that would be sufficient.
As SFTP protocol is different from FTP(S) this is considered as a new functionality to be added. Feel free to vote for this functionality. Top-rated suggestions are implemented faster.
