Unable to add Connection String in ASP.NET Settings: Error: aspnetcfg failed: Unable to cast object of type 'System.Xml.XmlComment' to type 'System.Xml.XmlElement'.
Created:
2016-11-16 12:46:49 UTC
Modified:
2017-08-16 16:40:13 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
Unable to add Connection String in ASP.NET Settings under Subscription if web.config of the domain contains comment like:
<!-- <add name="DefaultServer" connectionString="test"/> -->
The following error occurs:
(Error code 1)
This issue has been considered as software issue #PPPM-3943 and will be fixed in future product updates.
Workaround
There are two possible ways:
  1. Put the attached file aspnetconfiguration.dll to %plesk_bin% . Do not forget to backup the original file before.
  2. Upgrade to Plesk 12.5, since this issue has been fixed in Plesk 12.5 MU6.
