Various issues related to Mailenable
Created:
2016-11-16 12:46:35 UTC
Modified:
2017-08-16 16:13:22 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Windows
  • Plesk 12.0 for Windows
  • Plesk 12.5 for Windows
Unable to send and receive emails using Mailenable, despite of activity logs shows that emails were delivered to/(sent from) server:
2014-09-16 17:54:06 xxx.xxx.xxx.xxx SMTP-IN  xx.xxx.xxx.xx 868 MAIL MAIL+FROM:<mail.parallels@gmail.com>+SIZE=1528 250+Requested+mail+action+okay,+completed DSVR017441 43 51
2014-09-16 17:54:06 xxx.xxx.xxx.xxx SMTP-IN domain.tld xx.xxx.xxx.xx 868 RCPT RCPT+TO:<mail@domain.tld> 250+Requested+mail+action+okay,+completed DSVR017441 43 45
MTA settings were changed or configured manually.
  1. Check the registry settings for the MTA Mailenable service. In the command line, type:
    reg query "HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Mail Enable\\Mail Enable\\Agents\\MTA" | findstr Pick
You will receive output as below:
    Pickup Event Enabled    REG_DWORD    0x1
Pickup Event Timeout REG_DWORD 0xea60
Pickup Event Command Enabled REG_DWORD 0x0
Pickup Event Class Name REG_SZ pleskmemta.PleskMEMTA
Pickup Event Class Enabled REG_DWORD 0x1
Pickup Event Command REG_SZ
  1. If the output is different, please correct the MTA service settings in the registry (Start > Run > regedit.exe) as shown above.
  2. Restart Mailenable services.
