FTP connection over TLS failed: unable to accept TLS connection: received EOF that violates protocol
Created:
2016-11-16 12:46:04 UTC
Modified:
2017-08-08 13:27:59 UTC
1
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 12.0 for Linux
FTP connection over TLS failed with the following error in /var/log/plesk/ftp_tls.log :
2015-11-04 15:14:15,931 mod_tls/2.6[618]: TLS/TLS-C requested, starting TLS handshake
2015-11-04 15:14:36,868 mod_tls/2.6[618]: unable to accept TLS connection: received EOF that violates protocol
2015-11-04 15:14:36,868 mod_tls/2.6[618]: TLS/TLS-C negotiation failed on control channel
This behavior is usually be observed if the server is behind a router or firewall that inspects packets on the default port 21(for example ISA does not support FTP with TLS)
There are two possible solutions:
  • Disable filtering on the router/firewall/ISA server for 21 port.
  • Change ftp port in /etc/services to another (for example to 2121)
    1. Open /etc/services using ' vi ' and change the port for ftp to 2121 for both tcp/udp protocols.
      # vi /etc/services
    2. It should look like the following:
      # cat /etc/services  | grep 2121 | grep ftp
      ftp 2121/tcp
      ftp 2121/udp
    3. Restart xinetd service
      # service xinetd restart
    4. Check the FTP connection using new port.
