Not all images get published in Parallels Presence Builder
Created:
2016-11-16 12:44:19 UTC
Modified:
2017-08-16 16:52:33 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
There are many (more than 1000) pictures on a Web Presence Builder site (in Plesk ). After publishing, some images are missing on a publishing side. No error occurs in GUI when published.
After enabling debug logging according to this article , following records appear in /usr/local/psa/admin/logs/panel.log
Failed to copy file contents of //attachments/Image/1.jpg
Failed to copy file contents of //attachments/Image/2.jpg
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/3.jpg for reading: Too many open files
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/4.jpg for reading: Too many open files
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/5.jpg for reading: Too many open files
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/6.jpg for reading: Too many open files
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/7.jpg for reading: Too many open files
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/8.jpg for reading: Too many open files
Cannot open file /usr/local/psa/tmp/531561561235hj3oi13513h/attachments/Image/9.jpg for reading: Too many open files
Failed to set permissions or owner to //attachments/Image/10.jpgBad file descriptor
Failed to set permissions or owner to //attachments/Image/11.jpgBad file descriptor
Allowed number of file descriptors used for Nginx is low. Not all image files can be opened and therefore not all are transferred.
Add " worker_rlimit_nofile 16384; " string into http{} section of /etc/nginx/nginx.conf as shown below:
http {
include mime.types;
default_type application/octet-stream;
#log_format main '$remote_addr - $remote_user [$time_local] "$request" '
# '$status $body_bytes_sent "$http_referer" '
# '"$http_user_agent" "$http_x_forwarded_for"';
#access_log /var/log/nginx/access.log main;
sendfile on;
#tcp_nopush on;
Restart the services:
# /etc/init.d/sw-cp-server restart
# /etc/init.d/sw-engine restart
# /etc/init.d/nginx restart
