[INFO] How to downgrade a Plesk license key?
Created:
2016-11-16 12:43:56 UTC
Modified:
2017-08-16 17:38:54 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Windows
Provider configured Parallels Key Administrator plug-in in Parallels Business Automation - Standard (PBA-S) to sell Plesk license keys to customers.A customer needs to downgrade a Plesk license key, e.g. he purchased a Plesk license key with 100 domains and he needs to downgrade the license key to 10 domains.
This is by design that license capacity downgrade is disabled in customer's Parallels Key Administrator account (KA API login). Please contact your Sales Representative for more detail.
To change a license to a lower capacity, an existing license should be terminated and then a license of a lower capacity should be ordered.
Additional information
In order to terminate a Plesk license without terminating a Virtuozzo Container subscription, please perform the following steps:
  1. Login to PBA-S Provider's Panel (PCC) and follow Service Director > License Manager > Licenses .
  2. Find the license you want to terminate and click on it. On the license configuration page click the " Terminate " button.
To install a new license:
  1. Go to the customer's control panel.
  2. Select needed subscription and go to " Account " tab.
  3. Select " Upgrade Licenses " and you will be able to issue the new one.
