How to enable/disable graceful restart for Apache?
6 comments
    David Schroff
    The manual does not notice how to enable this change:
    /usr/local/psa/admin/bin/httpdmng --reconfigure-all
    Pavel Rozental
    Hello David, article is correct. It's not needed to run httpdmng command to apply changes.
    Justin
    No David is correct. I run a webapp from within Plesk, and simply completing this database edit did not do the job. My logs showed:
    503 POST {my uri} HTTP/1.0
    (104)Connection reset by peer: AH01075: Error dispatching request to :, referer: {my uri}
    Thank you David for posting the final step.
    Bulat Tsydenov
    s intende@Justin, Hi!
    Let me try to explain to you how it works and why it is actually not required to run httpdmng utility.
    The solution from this article is to add a particular parameter to Pleks database. Every time when Plesk runs reconfiguration of some configuration files, it checks the value of 'restart_apache_gracefully' parameter. If it is true, then Plesk will restart apache gracefully. If you run httpdmng after these steps, it will not make anything to achieve what this article is intended for.
    As for the errors, I believe they could have been resolved by running httpdmng to fix them, however, the cause of them different and the solution from this article makes nothing to fix them.
    Stéphan Schamp
    To enable:
    INSERT INTO psa.misc VALUES ('restart_apache_gracefully', 'true') ON DUPLICATE KEY UPDATE val='true';
    To disable:
    INSERT INTO psa.misc VALUES ('restart_apache_gracefully', 'false') ON DUPLICATE KEY UPDATE val='false';
    Rhein Web
    VERY VERY HELPFULL TO AVOID 502 NGINX ERRORS !!!
