How to uninstall Plesk for Linux
2 comments
    Gökhan Sever
    I get an error. Where to upload plesk._remove.zip file to ftp.
    unzip plesk._remove.zip unzip: cannot find or open plesk._remove.zip, plesk._remove.zip.zip or plesk._remove.zip.ZIP.
    Konstantin Annikov
    Hello,
    Thank you for the feedback.
    I have modified the article. Extra "." symbol was defined in the command. Pleease try now with the following command after uploading file via ftp:
    #  unzip plesk_remove.zip
