ASP.NET domain with redirect setup is not accessible: 404 not found
Created:
2016-11-16 12:41:59 UTC
Modified:
2017-08-08 13:29:46 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
404 Not Found
The page you are looking for might have been removed, had it's name changed, or is temporarily unavailable
Domain's web.config file contains redirects similar to:
<add name="sample_folder" virtualUrl="^~/sample_folder/" rewriteUrlParameter="ExcludeFromClientQueryString" destinationUrl="~/default.aspx" ignoreCase="true" />
sample_folder is missing in "%plesk_vhosts%"\\example.com\\httpdocs\\
Incorrect redirects are setup in web.config file or contents of sample_folder folder are missing
Edit web.config file so that it redirects to existing files, or add content to sample_folder folder in "%plesk_vhosts%"\\example.com\\httpdocs\\
