- Plesk 12.5 for Linux
- Plesk 11.x for Linux
An attempt to create database dump fails with the following error:
mysqldump: unknown option '--max_allowed_packet 512M'
The
/etc/my.cnf
has the following option:[mysqldump]
Incorrect syntax in
/etc/my.cnf
, the option name and the value should be separated with '=' symbol.
Edit
/etc/my.cnf
, you can use thevi /etc/my.cnf
command for example.The
max_allowed_packet
requires '=' symbol before size number, so it should look like:[mysqldump]
max_allowed_packet=512M -
Restart
mysql
:service mysql restart
