How to back up/restore Plesk system databases
4 comments
    Alex Rubio Cazador
    I have a issue when i try to do this command included in a crontab
    plesk db dump DATABASE_NAME > C:\FULL\PATH\TO\FILE_NAME.sql
    when I execute manually the command runs perfect and i can backup all my sql files, but when i use this comend inside a crontab, they create and retund the .sql files empty
    Thank you.
    Denis Bykov
    @Alex Rubio Cazador
    Try using the full path to the executable instead of the alias:
    For Linux:
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysqldump -u admin DATABASE_NAME > /full/path/to/BACKUP_FILE_NAME.sql
    For Windows Server:
    C:\>"%plesk_dir%\Mysql\bin\mysqldump.exe" -uadmin -p<plesk_admin_password> -P8306 DATABASE_NAME > C:\FULL\PATH\TO\FILE_NAME.sql
    santhosh
    hai am new to plesk am getting error while am updating plesk
    Internal error: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'psa.ServiceInstallations' doesn't exist
    how to rectify this error
    Ivan Postnikov
    Hello @santhosh,
    This behavior may be caused by several issues:
    • Server is running out of RAM.
    • Some limits are exceeded on a container or on a hardware node.
    1. Connect to the server via SSH;
    2. Make sure that it is enough memory or container resources:
      # free -m
      # cat /proc/user_beancounters
      There should be enough memory and all 'failcnt' values should be 0.
      Do the following in order to fix the issue:
      1. If you are leasing a virtual container, please contact your service provider in order to increase container limits.
      2. Increase amount of RAM or SWAP on the server.
    3. After fixing the limits issue, re-run the upgrade How to upgrade Plesk to the next release
    Check this article for reference:
    https://support.plesk.com/hc/en-us/articles/360006408573-Unable-to-open-Plesk-after-upgrade-Table-psa-ServiceInstallations-doesn-t-exist
