502 Bad Gateway error is shown after login to Plesk or performing any actions: Connection reset by peer
4 comments
    Wolfgang Freudenberger
    We got this problem today on a Onyx 17.5.3 machine while trying to edit emailadresses. This workaround help - perhaps it should be considered to mark this solution for Onyx, too.
    Alexandr Redikultsev
    Hi @Wolfgang Freudenberger!
    Have you tried just restarting sw-cp-server and sw-engine before applying any changes to /etc/sw-cp-server/config?
    There is a probability that the issue was fixed just by the restart.
    It would be great if you check that (for example, reverting the settings back for a moment and checking whether or not the issue is still there).
    In case adjusting of /etc/sw-cp-server/config is indeed required, I will definitely add this info to the article!
    Thanks.
    Hi @Alexandr Redikultsev,
    Yep, tried everything, no chance of bringing the page back to life. This fix was the only way. It is kind of difficult to debug a 502 without any specific error. :D
    Hi @Wolfgang Freudenberger.
    Alright, I will add the note, thank you for sharing with us.
