- Plesk for Windows
Plesk interface is not accessible with one of the errors:
CONFIG_TEXT: ERROR: Zend_Db_Statement_Exception
SQLSTATE[HY000]: General error: 1030 Got error -1 from storage engineOR
CONFIG_TEXT: Error: Failed to connect to MySQL: ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
OR
CONFIG_TEXT: Server Error
500
Plesk\Exception\Database
DB query failed: SQLSTATE[HY000]: General error: 1881 Operation not allowed when innodb_forced_recovery > 0., query was: INSERT INTO sessions (sess_id, type, login, ip_address, login_time, modified, lifetime) VALUES (?, ?, ?, ?, ?, ?, ?)OR
500
DB query failed: SQLSTATE[HY000]: General error: 1036 Table 'sessions' is read only, query was: INSERT INTO `sessions` (`sess_id`, `type`, `login`, `ip_address`, `login_time`, `modified`, `lifetime`) VALUES (?, ?, ?, ?, ?, ?, ?) -
In the MySQL configuration file (
/etc/my.cnf
or/etc/mysql/my.cnf
on Plesk for Linux,%plesk_dir%MySQL\my.ini
on Plesk for Windows), the parameterinnodb_force_recovery
is set to the value more than 0:# grep innodb_force_recovery /etc/my.cnf
innodb_force_recovery=4 -
Restoration of the database from Plesk backup fails:
PLESK_ERROR: Stderr is ERROR 1881 (HY000) at line 48 in file: 'C:\Program Files (x86)\Parallels\Plesk\PrivateTemp\pmm-ru-udb-dump-01d4f884b411e470\pmm-mysdp-dd-dump-e7566891d2ba42a4a9306c12c48e53dc': Operation not allowed when innodb_forced_recovery > 0.
WordPress login page redirects to https://example.com/wp-login.php?redirect_to=https%3A%2F%2Fexample.com%2Fwp-admin%2F&reauth=1 after enteting login and password.
With WordPress debug enabled, the following message is logged:CONFIG_TEXT: [Operation not allowed when innodb_forced_recovery > 0.]
The option innodb_force_recovery
is enabled and prevents MySQL from functioning properly.
Note: This article is intended for use by server administrators. In case there is no administrative SSH or RDP access to the server, contact the server administrator or server provider.
Disable the option
in the MySQL configuration:-
Plesk for Linux
Open the file
/etc/my.cnf
(/etc/mysql/my.cnf
on Debian and Ubuntu) for editing. -
Remove the line which contains the option
and save the file. -
Restart MySQL service to apply the change (depending on the operating system, service can be called
mysql
ormariadb
):# service mysqld restart
Plesk for Windows
- Open the file
in any text editor. -
Open the Services snap-in:
- in Windows Server 2008 and 2008 R2: go to Start > Administrative Tools > Services.
- in Windows Server 2012 and newer: go to Start > Server Manager > Tools > Services.
Select Plesk SQL Server and click Restart.
- Open the file
Note: If after removing the line with the option innodb_force_recovery
MySQL service still fails to start, it is required to fix InnoDB corruption.
Depending on used operating system, follow one of the articles below for doing that:
How to fix InnoDB corruption cases for the MySQL databases on Plesk for Linux?
How to fix InnoDB corruption cases for the MySQL databases on Plesk for Windows?
