How to check that domain on Plesk has a correct SPF record?
The most simple solution is to use online tools like the following below:
http://www.kitterman.com/spf/validate.html
If there is no SPF DNS record found after test, do the following:
- Make sure that SPF, DKIM, DMARC (for Plesk Onyx 17.0 and higher) are enabled in Tools & Settings > Mail Server settings
- Make sure that DKIM signing is enabled in Domains > example.com > Mail Settings - Use DKIM spam protection system to sign outgoing email messages (optional, if required)
- Make sure that Domains > example.com > DNS Settings contains similar records
- Wait 24-32 hours for DNS propagation and check again.
Connect to the Linux server or use Terminal (How to connect to a server using SSH/RDP ):
- Try to query with a command provided by libspf2 library like as below:
# /usr/bin/spfquery_static -ip 10.20.30.40 -sender from@example.com -rcpt-to to@example.com
A correctly set domain will print like this (using Google as an example):
# /usr/bin/spfquery_static -ip 66.102.13.18 -sender from@gmail.com -rcpt-to to@gmail.com
pass
spfquery: domain of gmail.com designates 66.102.13.18 as permitted sender
Received-SPF: pass (spfquery: domain of gmail.com designates 66.102.13.18 as permitted sender) client-ip=66.102.13.18; envelope-from=from@gmail.com; -
A problematic domain looks more like this:
# /usr/bin/spfquery_static -ip 11.22.33.44 -sender from@example.com -rcpt-to to@gmail.com
StartError
Context: Failed to query MAIL-FROM
ErrorCode: (26) DNS lookup failure
Error: Temporary DNS failure for 'example.com'.
EndError
(invalid)neutral
Please see http://www.openspf.org/Why?id=from%40example.com&ip=11.22.33.44&receiver=spfquery : Reason: default
spfquery: 11.22.33.44 is neither permitted nor denied by domain of example.com
Received-SPF: neutral (spfquery: 11.22.33.44 is neither permitted nor denied by domain of example.com) client-ip=11.22.33.44; envelope-from=from@example.com; -
To check that DNS server has information about SPF for domain
example.com
, use thedig
utility:# dig -t TXT +short example.com @13.23.33.43
"v=spf1 +a +mx -all +a:server.hostname.tld"where
13.23.33.43
IP address of theserver.hostname.tld
where DNS server is running.
Information
Note that the SPF information can be written in either TXT format or as a dedicated SPF record. The latter is also sometimes referred to as a "type99" record. The SPF information needs to be in at least one of these formats. If both are used, these records must be exact copies of each other. These records are served by the same DNS server that serves
example.com
domain name.
Library
libspf2
performs an SPF check in the following order: - First, it queries the DNS server for an SPF record. - If it is not defined, it tries to query for TXT. - If both attempts fail, it means there is no SPF for this domain.
For more information check Plesk Documentation and Help Portal - Sender Policy Framework System (Linux)
