How to set connection/execution timeout values in MylittleAdmin?
Created:
2016-11-16 12:39:04 UTC
Modified:
2017-08-16 17:17:46 UTC
Have more questions?
Submit a request
  • Plesk for Windows
How to set default connection/execution timeout values for MylittleAdmin?
  1. Connect to the server using RDP .
  2. Open config.xml which is located:
    For Plesk 11.0 and 11.5 at %plesk_vhosts%sqladmin\myLittleAdmin\2005\
    For Plesk 12.0 and higher at %plesk_dir%MyLittleAdmin
  3. Edit <connectiontimeout value="15" /> to set how long to wait while establishing a connection before terminating the attempt and generating an error.
    Edit <executiontimeout value="0" /> to set the maximum number of seconds that a request is allowed to execute before being automatically shut down by ASP.NET.
Note: Create a backup of config.xml before making any changes.
2 Comments
  • 0
    Avatar
    Leslie Jegan
    I found the config.xml file under "c:\Program files(x86)\Plesk\MyLittleAdmin\"
    Note: Before making any changes, please take a backup of the config file
  • 0
    Avatar
    Artyom Baranov
    Hi Leslie,
    Indeed, since Plesk 12.0 the location of `config.xml` has been changed. I have updated the article according to your feedback, thank you!
