Unable to manage ASP.NET settings of domain virtual directories
Created:
2016-11-16 13:26:04 UTC
Modified:
2017-08-16 17:21:44 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
Unable to manage ASP.NET settings in Plesk > Websites & Domains > example.com > Virtual Directories > Create Virtual Directory > ASP.NET 4.6 , when the website is using ASP.NET 3.5 in Plesk > Websites ans Domains > example.com > ASP.NET Settings . The following error message appears:
The operation you were performing failed. You can retry the operation with or without changing its parameters. You may also want to report this problem to our support so that we could help you as soon as possible.
This is Plesk internal issue with ID #PPPM-4489 , which is planned to be fixed in future Plesk updates.
Workaround
NOTE : The patch can only be applied to Plesk 12.0.
  1. Download zip archive.
  2. Extract the downloaded package and copy aspnetcfg.exe and aspnetconfiguration.dll to %plesk_dir%\\admin\\bin directory.
