PleskFatalException: Unable to obtain secret key for passwords encryption.
Created:
2016-11-16 13:25:59 UTC
Modified:
2017-08-16 16:05:58 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 10.x for Linux
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
The following error message appears while accessing Plesk or during installation:
The Plesk upgrade or installation failed.
  1. To fix the encryption error, regenerate the encryption key:
     /usr/local/psa/admin/sbin/encrypt_keygen
    You may see the following error:
    # /usr/local/psa/admin/sbin/encrypt_keygen
    Unable to generate new key - key file exists
    However, this utility fixes permissions for encryption key file in this case, so the error can be ignored.
  2. Run the Bootstrapper script with the below parameters to fix upgrade issues:
    /usr/local/psa/bootstrapper/pp<version>-bootstrapper/bootstrapper.sh repair
    if the case is upgrade to Plesk 12.5.30, <version> should be 12.5.30
