Class "VPNKey_Common_UploadForm" not found
Created:
2016-11-16 13:25:22 UTC
Modified:
2017-08-16 16:56:47 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
VPN extension was installed into Plesk.
'Install key' button produces the following error:
This is a product issue with ID #PPP-3785. The issue was completely fixed in Plesk 12.
Upgrade to 12, in order to use the 'Install key' feature.
As a work around, you may generate a new key by using 'Generate key' button, download it and install it on a VPN client you will use for connections.
