What is Plesk Mirror Setup Tool v3.1.4 and how to use it?
3 comments
    Technical
    The following problem occurs when mirroring
    Trying to get 'products.inf3' from 'rsync://rsync.autoinstall-win.pp.parallels.com/autoinstall'... rsync: getaddrinfo: rsync.autoinstall-win.pp.parallels.com 873: Name or service not known
    rsync error: error in socket IO (code 10) at clientserver.c(125) [Receiver=3.1.2]
    ERROR: Empty error message from exec command: /bin/rm -f /root/mirrorctl-3.1.3/BUILD/products.inf3;mkdir -p /root/mirrorctl-3.1.3/BUILD/`dirname products.inf3`;rsync -auv --copy-links rsync://rsync.autoinstall-win.pp.parallels.com/autoinstall/products.inf3 /root/mirrorctl-3.1.3/BUILD/products.inf3
    rsync.autoinstall-win.pp.parallels.com no a record, how to specify the source ?
    Yaroslav Tarasov (Edited )
    Hello,
    You are right. The URL rsync.autoinstall-win.pp.parallels.com is not a valid one. This is a bug PPPM-13536 in Mirrorctl v.3.1.3.
    It's required to open path_to_your_Mirrorctl/lib/Options.php file with a text editor (e.g. Notepad) and modify the values of variables $options['repos_rsync'] or $options['repos_rsync_win'] to rsync://ch.origin.autoinstall-win.plesk.com/autoinstall or rsync://rsync.autoinstall.plesk.com/autoinstall (as in "Prerequisites - step 4" of this article)
    Appreciate your understanding.
    Mahdi HZ
    When I get os list, I can see Almalinux (al8_x86_64)
    [root@plesk mirrorctl-3.1.4]# ./mirrorctl os-list --release=PLESK_18_0_50
    Trying to get 'products.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.50_10904/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.49_10759/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.48_10183/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.47_10005/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.46_9775/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.45_9299/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.44_9078/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'pool/PSA_18.0.43_8703/release.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'plesk.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    Trying to get 'sitebuilder.inf3' from 'rsync://rsync.autoinstall.plesk.com/autoinstall'... ok
    The following operating systems are available for the release PLESK_18_0_50:
        al8_x86_64
        al9_x86_64
        cos7_x86_64
        cl7_x86_64
        cl8_x86_64
        deb10.0_x86_64
        deb11.0_x86_64
        rhel7_x86_64
        rhel8_x86_64
        rhel9_x86_64
        ro8_x86_64
        ubt18.04_x86_64
        ubt20.04_x86_64
        ubt22.04_aarch64
        ubt22.04_x86_64
    But in rsync a got error for AlmaLinux
    sent 20 bytes  received 72 bytes  61.33 bytes/sec
    total size is 84,850  speedup is 922.28
    Getting Plesk packages for PLESK_18_0_50/al8_x86_64
    receiving incremental file list
    rsync: link_stat "/pool/PSA_18.0.50_10904/dist-rpm-AlmaLinux-8-x86_64" (in autoinstall) failed: No such file or directory (2)
    rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1651) [Receiver=3.1.2]
    sent 8 bytes  received 137 bytes  96.67 bytes/sec
    total size is 0  speedup is 0.00
    Getting Plesk updates for PLESK_18_0_50/al8_x86_64
    rsync: link_stat "/pool/PSA_18.0.50_10904/update-rpm-AlmaLinux-8-x86_64" (in autoinstall) failed: No such file or directory (2)
    sent 8 bytes  received 139 bytes  98.00 bytes/sec
    Getting Plesk thirdparty components for PLESK_18_0_50/al8_x86_64
    rsync: link_stat "/pool/PSA_18.0.50_10904/thirdparty-rpm-AlmaLinux-8-x86_64" (in autoinstall) failed: No such file or directory (2)
    sent 8 bytes  received 143 bytes  100.67 bytes/sec
    Getting Plesk extra packages for PLESK_18_0_50/al8_x86_64
    rsync: link_stat "/pool/PSA_18.0.50_10904/extras-rpm-AlmaLinux-8-x86_64" (in autoinstall) failed: No such file or directory (2)
    How i can fix this?
