It is not possible to change language in PHPMyadmin
Created:
2016-11-16 13:24:28 UTC
Modified:
2017-08-16 16:49:04 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Windows
  • Plesk 11.x for Linux
It is not possible to change language or perform group operation (ex, delete several tables at once) in PHPMyadmin. When I perform changes in PHPMyadmin, nothing happens and I do not get any error.
Possible reason is not updated phpMyadmin.
  1. Launch autoinstaller:
    "%plesk_bin%"\\ai --console
  2. Click Next till you get list of installed packages. Make sure that PHPMyadmin is updated (it should be marked with = sign). If you see that PHPMyadmin is mark with * as below it means that package is not updated:
     1.  *  Base packages of Parallels Plesk Panel
    2. [*] Parallels Plesk Panel
    5. [=] BIND DNS Server
    11.[*] PHPMyAdmin
  3. Click Next and update packages.
