- Plesk for Windows
Web statistics are not calculated automatically but calculating the statistics for a single domain works correctly
The Traffic column in Domains shows 0 for all websites
Going to Windows > Task Scheduler, the scheduled task Plesk Scheduler Task - Daily web statistics analyzers run task is misconfigured
Connect to the server via RDP
Go to Task Scheduler > Task Scheduler Library and select one of the following use cases:
Scheduled task doesn't existStart a command prompt as Administrator and run the following command to recreate the scheduled task:
C:\> "%plesk_bin%\crontabmng.exe" create-web-stat-executor-task
Scheduled task is stuckIn the case that the scheduled task is stuck with Running status, restart the server to make sure the process is free up properly
To calculate the traffic statistics for all the domains and verify the issue was solved, Right-click on the scheduled task and press Run. Once the scheduled task will finish, log in to Plesk GUI and verify that the Traffic statistics are displayed correctly.
