Disable weak SSL/TLS ciphers for PCI Complaince
Created:
2016-11-16 13:23:14 UTC
Modified:
2017-08-17 18:38:06 UTC
2
Have more questions?
Submit a request
  • Plesk for Linux
  • Plesk 11.x for Linux
  • Plesk 12.0 for Windows
  • Plesk 12.0 for Linux
Server should meet the following PCI compliance requirements:
  • Configure SSL/TLS servers to only use TLS 1.1 or TLS 1.2 if supported.
  • Configure SSL/TLS servers to only support cipher suites that do not use block ciphers.
However, these protocols are not supported in Plesk by default.
PCI compliance requires that you enable the TLS 1.1 and TLS 1.2 protocols, but they are supported by Apache web server starting from 2.2.23 version.
  1. Make sure that all system packages are up to date and the latest Plesk microupdate has installed
  2. Follow instructions provided in the article #213933745 - CVE-2015-4000 LOGJAM TLS DH vulnerability
