Unable to reset Default site for an IP address: Site does not exist in IIS
Created:
2016-11-16 13:22:56 UTC
Modified:
2017-08-08 13:39:57 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Windows
Unable to set Default site as None for an IP address at Home > Tools & Settings > IP Addresses > :
Error: Site example.com does not exist at IISWebSites::get() In IIS7NativeProvider module Exception type: System.Exception at IISWebSites.get(IISWebSites* , unique_ptr >* , basic_string\\,std::allocator >* idnName) at resetDefaultDomainForIp(203.0.113.2)(WebServerAdapter::resetDefaultDomainForIp line 1170) at execute console command --reset-default-domain(vconsoleapp::start line 100) at execute "C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\bin64\\websrvmng.exe" --reset-default-domain "--ip-address=203.0.113.2"(vconsoleapp::run line 117) (Error code 1)
The domain does not exist in Plesk as well as in IIS.
Old site cache in IIS.
Remove the site cache from IIS with the following command via command prompt in privileged mode (as Administrator):
"%plesk_dir%"\\admin\\bin\\websrvmng.exe --remove-sites-cache
