Plesk and its command-line utilities do not work due to missing Plesk packages
6 comments
    Leslie Bray
    None of these commands work.
    plesk-installer     100%[===================>]   9.24K  --.-KB/s    in 0s
    2019-04-28 18:06:15 (222 MB/s) - 'plesk-installer' saved [9465/9465]
    bash-4.3$ # chmod +x plesk-installer./plesk-installer
    bash-4.3$ 1. [*] Plesk
    bash: 1.: command not found
    bash-4.3$ 2. [=] BIND DNS server plesk
    bash: 2.: command not found
    bash-4.3$ * Plesk
    bash-4.3$ (*) Plesk
    bash: syntax error near unexpected token `Plesk'
    bash-4.3$ 1. (*) Plesk
    bash: syntax error near unexpected token `*'
    bash-4.3$ .plesk-installer
    bash: .plesk-installer: command not found
    bash-4.3$ wget http://autoinstall.plesk.com/plesk-installer
    --2019-04-28 18:13:10--  http://autoinstall.plesk.com/plesk-installer
    Resolving autoinstall.plesk.com (autoinstall.plesk.com)... (//////////)
    Connecting to autoinstall.plesk.com (autoinstall.plesk.com)(----------)... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 9465 (9.2K) [application/octet-stream]
    Saving to: 'plesk-installer.1'
    plesk-installer.1   100%[===================>]   9.24K  --.-KB/s    in 0s
    2019-04-28 18:13:12 (242 MB/s) - 'plesk-installer.1' saved [9465/9465]
    bash-4.3$ chmod +x plesk-installer
    bash-4.3$ (*) Plesk
    bash-4.3$ plesk
    bash: plesk: command not found
    bash-4.3$ * Plesk
    bash-4.3$ = bind dns server
    bash: =: command not found
    bash-4.3$ unlink /usr/local/psa
    bash: unlink: command not found
    bash-4.3$ rm -rf/usr/local/psa
    rm: invalid option -- '/'
    Data Network
    Hello, I remove postfix with apt-get purge postfix command,, I did realize that some plesk packages were deleted, my foul,,
    with command
    grep remove /var/log/dpkg.log | grep 'psa\|plesk'
    I have:
    2019-05-07 11:41:33 remove plesk-config-troubleshooter:amd64 17.8.11-debian9.0.build1708190219.21 <none>
    2019-05-07 11:41:34 remove plesk-l10n:all 17.8.11-debian9.0.build1708181025.13 <none>
    2019-05-07 11:41:36 remove psa-drweb-configurator:amd64 17.8.11-debian9.0.build1708180301.19 <none>
    2019-05-07 11:41:36 remove psa-spamassassin:amd64 17.8.11-debian9.0.build1708180301.19 <none>
    2019-05-07 11:41:39 remove plesk-mail-pc-driver:amd64 17.8.11-debian9.0.build1708180927.11 <none>
    2019-05-07 11:41:43 remove plesk-management-node:amd64 17.8.11-debian9.0.build1708180301.19 <none>
    2019-05-07 11:41:43 remove plesk-repair-kit:all 17.8.11-debian9.0.build1708190322.14 <none>
    2019-05-07 11:41:44 remove psa-firewall:amd64 17.8.11-debian9.0.build1708180301.19 <none>
    2019-05-07 11:41:45 remove psa-updates:all 17.8.11-debian9.0.build1708180326.12 <none>
    2019-05-07 11:41:45 remove plesk-core:amd64 17.8.11-debian9.0.build1708180301.19 <none>
    my question is,,, is it safe ./plesk-installer..?
    will I lost information..?
    Nikita Nikushkin
    Hi @Data Network,
    Yes, you are right here - in order to install removed files back, download Plesk installer, run it and follow instructions on the screen:
    # wget https://autoinstall.plesk.com/plesk-installer
    # ./plesk-installer
    Depends on which information we are talking about...Websites, mail, databases will not be affected, however, configuration files were removed by specifying the "purge" directive previously, so, all customization in such configs will be lost
    Gjimi
    after update 15.07.2020 (CET) there are various errors
    traps: php-fpm[29587] trap invalid opcode ip:55ccc882de14 sp:7ffdf85b44e0 error:0 - in php-fpm[55ccc845b000+4c8000]
    Website: Error 500
    # plesk repair installation:
    WARNING:Skip fixing 'plesk-config-troubleshooter': Cannot find deb-archive for package plesk-config-troubleshooter (18.0-v.debian.9+p18.0.28.1+t200630.1010)
    WARNING:Skip fixing 'plesk-libboost-1.65': Cannot find deb-archive for package plesk-libboost-1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-atomic1.65': Cannot find deb-archive for package plesk-libboost-atomic1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-chrono1.65': Cannot find deb-archive for package plesk-libboost-chrono1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-date-time1.65': Cannot find deb-archive for package plesk-libboost-date-time1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-filesystem1.65': Cannot find deb-archive for package plesk-libboost-filesystem1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-iostreams1.65': Cannot find deb-archive for package plesk-libboost-iostreams1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-log1.65': Cannot find deb-archive for package plesk-libboost-log1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-program-options1.65': Cannot find deb-archive for package plesk-libboost-program-options1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-regex1.65': Cannot find deb-archive for package plesk-libboost-regex1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-serialization1.65': Cannot find deb-archive for package plesk-libboost-serialization1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-system1.65': Cannot find deb-archive for package plesk-libboost-system1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-libboost-thread1.65': Cannot find deb-archive for package plesk-libboost-thread1.65 (1.65.1-debian.9.171017.1047)
    WARNING:Skip fixing 'plesk-liblog4cpp-0.3.5': Cannot find deb-archive for package plesk-liblog4cpp-0.3.5 (0.3.5rc2-debian.9.171017.1348)
    WARNING:Skip fixing 'plesk-libpoco-1.7.8': Cannot find deb-archive for package plesk-libpoco-1.7.8 (1.7.8p3-debian.9.171017.1154)
    WARNING:Skip fixing 'plesk-libstdc++6.3.0': Cannot find deb-archive for package plesk-libstdc++6.3.0 (6.3.0-debian.9.171005.2356)
    WARNING:Skip fixing 'plesk-milter': Cannot find deb-archive for package plesk-milter (8.14.5-debian.9.171117.1620)
    WARNING:Skip fixing 'plesk-resctrl': Cannot find deb-archive for package plesk-resctrl (18.0-v.debian.9+p18.0.28.1+t200630.1010)
    WARNING:Skip fixing 'pp17.8.11-bootstrapper': Cannot find deb-archive for package pp17.8.11-bootstrapper (17.8.11-debian9.0.build1708190409.21)
    WARNING:Skip fixing 'psa-pear': Cannot find deb-archive for package psa-pear (1.10.5-20180124.debian9.0.18012417)
    WARNING:Skip fixing 'sw-engine-cli-2.24': Cannot find deb-archive for package sw-engine-cli-2.24 (2.24.13-debian.9.190731.1634)
    # apt download psa-pear
    E: Can't find a source to download version '1.10.5-20180124.debian9.0.18012417' of 'psa-pear:amd64'
    Ivan Postnikov
    Hello Gjimi
    As I can see, you've created a support request already. Please, expect an update there.
    Such issues usually require additional investigation.
    Nikita Nikushkin
    Hi @Leslie Bray,
    As far as I can see, you are not logged as root and thus, most of the commands, do not work for you
    Connect to the server as root and try the commands one more time
