Plesk is not accessible with a "404 Not found nginx" error.
Plesk command-line utilities are unavailable, for example:
# plesk bin domain -l
Unknown Plesk command-line utility: "domain" -
Plesk version cannot be retrieved:
# plesk -v
open /usr/local/psa/version: no such file or director -
The plesk-core package is missing on the server:
# rpm -qa | grep plesk-core
Plesk installation is corrupted: the Plesk packages have been removed according to a package manager log:
On CentOS/RHEL-based distributions:
# grep Erased /var/log/yum.log | grep 'psa\|plesk'
Nov 01 10:00:00 Erased: psa-firewall-17.8.11-cos7.build1708180301.19.x86_64
Nov 01 10:00:00 Erased: psa-updates-17.8.11-cos7.build1708180326.12.noarch
Nov 01 10:00:00 Erased: plesk-core-17.8.11-cos7.build1708180301.19.x86_64
On Debian/Ubuntu-based distributions:
# grep remove /var/log/dpkg.log | grep 'psa\|plesk'
2018-01-01 10:00:00 remove psa-mnemo:all 4.2.14-debian8.0.build1708180425.15 <none>
2018-01-01 10:00:00 remove psa-updates:all 17.8.11-debian8.0.build1708180326.12 <none>
2018-01-01 10:00:00 remove plesk-core:amd64 17.8.11-debian8.0.build1708180301.19 <none>
Download Plesk Installer:
# wget http://autoinstall.plesk.com/plesk-installer
# chmod +x plesk-installer -
Start Plesk Installer and install missing packages:
# ./plesk-installer
On the Main components list for Plesk page, select Plesk for installation and proceed further.
MYSQL_LIN: Main components list for Plesk
31 of 55 components selected
Please select the components of Plesk you want to install:
1. [*] Plesk
2. [=] BIND DNS server
On Debian/Ubuntu-based distributions, re-link Plesk installation directory using these commands:
# unlink /usr/local/psa
# rm -rf /usr/local/psa
# ln -s /opt/psa /usr/local/psa -
Log in to Plesk. If Plesk does not load, restore the Plesk database from a daily dump.
6 comments
None of these commands work.
plesk-installer 100%[===================>] 9.24K --.-KB/s in 0s
2019-04-28 18:06:15 (222 MB/s) - 'plesk-installer' saved [9465/9465]
bash-4.3$ # chmod +x plesk-installer./plesk-installer
bash-4.3$ 1. [*] Plesk
bash: 1.: command not found
bash-4.3$ 2. [=] BIND DNS server plesk
bash: 2.: command not found
bash-4.3$ * Plesk
bash-4.3$ (*) Plesk
bash: syntax error near unexpected token `Plesk'
bash-4.3$ 1. (*) Plesk
bash: syntax error near unexpected token `*'
bash-4.3$ .plesk-installer
bash: .plesk-installer: command not found
bash-4.3$ wget http://autoinstall.plesk.com/plesk-installer
--2019-04-28 18:13:10-- http://autoinstall.plesk.com/plesk-installer
Resolving autoinstall.plesk.com (autoinstall.plesk.com)... (//////////)
Connecting to autoinstall.plesk.com (autoinstall.plesk.com)(----------)... connected.
HTTP request sent, awaiting response... 200 OK
Length: 9465 (9.2K) [application/octet-stream]
Saving to: 'plesk-installer.1'
plesk-installer.1 100%[===================>] 9.24K --.-KB/s in 0s
2019-04-28 18:13:12 (242 MB/s) - 'plesk-installer.1' saved [9465/9465]
bash-4.3$ chmod +x plesk-installer
bash-4.3$ (*) Plesk
bash-4.3$ plesk
bash: plesk: command not found
bash-4.3$ * Plesk
bash-4.3$ = bind dns server
bash: =: command not found
bash-4.3$ unlink /usr/local/psa
bash: unlink: command not found
bash-4.3$ rm -rf/usr/local/psa
rm: invalid option -- '/'
Hi @Leslie Bray,
As far as I can see, you are not logged as root and thus, most of the commands, do not work for you
Connect to the server as root and try the commands one more time
Hello, I remove postfix with apt-get purge postfix command,, I did realize that some plesk packages were deleted, my foul,,
with command
I have:
2019-05-07 11:41:33 remove plesk-config-troubleshooter:amd64 17.8.11-debian9.0.build1708190219.21 <none>
2019-05-07 11:41:34 remove plesk-l10n:all 17.8.11-debian9.0.build1708181025.13 <none>
2019-05-07 11:41:36 remove psa-drweb-configurator:amd64 17.8.11-debian9.0.build1708180301.19 <none>
2019-05-07 11:41:36 remove psa-spamassassin:amd64 17.8.11-debian9.0.build1708180301.19 <none>
2019-05-07 11:41:39 remove plesk-mail-pc-driver:amd64 17.8.11-debian9.0.build1708180927.11 <none>
2019-05-07 11:41:43 remove plesk-management-node:amd64 17.8.11-debian9.0.build1708180301.19 <none>
2019-05-07 11:41:43 remove plesk-repair-kit:all 17.8.11-debian9.0.build1708190322.14 <none>
2019-05-07 11:41:44 remove psa-firewall:amd64 17.8.11-debian9.0.build1708180301.19 <none>
2019-05-07 11:41:45 remove psa-updates:all 17.8.11-debian9.0.build1708180326.12 <none>
2019-05-07 11:41:45 remove plesk-core:amd64 17.8.11-debian9.0.build1708180301.19 <none>
my question is,,, is it safe ./plesk-installer..?
will I lost information..?
Hi @Data Network,
Yes, you are right here - in order to install removed files back, download Plesk installer, run it and follow instructions on the screen:
Depends on which information we are talking about...Websites, mail, databases will not be affected, however, configuration files were removed by specifying the "purge" directive previously, so, all customization in such configs will be lost
after update 15.07.2020 (CET) there are various errors
traps: php-fpm[29587] trap invalid opcode ip:55ccc882de14 sp:7ffdf85b44e0 error:0 - in php-fpm[55ccc845b000+4c8000]
Website: Error 500
# plesk repair installation:
WARNING:Skip fixing 'plesk-config-troubleshooter': Cannot find deb-archive for package plesk-config-troubleshooter (18.0-v.debian.9+p18.0.28.1+t200630.1010)
WARNING:Skip fixing 'plesk-libboost-1.65': Cannot find deb-archive for package plesk-libboost-1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-atomic1.65': Cannot find deb-archive for package plesk-libboost-atomic1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-chrono1.65': Cannot find deb-archive for package plesk-libboost-chrono1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-date-time1.65': Cannot find deb-archive for package plesk-libboost-date-time1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-filesystem1.65': Cannot find deb-archive for package plesk-libboost-filesystem1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-iostreams1.65': Cannot find deb-archive for package plesk-libboost-iostreams1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-log1.65': Cannot find deb-archive for package plesk-libboost-log1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-program-options1.65': Cannot find deb-archive for package plesk-libboost-program-options1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-regex1.65': Cannot find deb-archive for package plesk-libboost-regex1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-serialization1.65': Cannot find deb-archive for package plesk-libboost-serialization1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-system1.65': Cannot find deb-archive for package plesk-libboost-system1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-libboost-thread1.65': Cannot find deb-archive for package plesk-libboost-thread1.65 (1.65.1-debian.9.171017.1047)
WARNING:Skip fixing 'plesk-liblog4cpp-0.3.5': Cannot find deb-archive for package plesk-liblog4cpp-0.3.5 (0.3.5rc2-debian.9.171017.1348)
WARNING:Skip fixing 'plesk-libpoco-1.7.8': Cannot find deb-archive for package plesk-libpoco-1.7.8 (1.7.8p3-debian.9.171017.1154)
WARNING:Skip fixing 'plesk-libstdc++6.3.0': Cannot find deb-archive for package plesk-libstdc++6.3.0 (6.3.0-debian.9.171005.2356)
WARNING:Skip fixing 'plesk-milter': Cannot find deb-archive for package plesk-milter (8.14.5-debian.9.171117.1620)
WARNING:Skip fixing 'plesk-resctrl': Cannot find deb-archive for package plesk-resctrl (18.0-v.debian.9+p18.0.28.1+t200630.1010)
WARNING:Skip fixing 'pp17.8.11-bootstrapper': Cannot find deb-archive for package pp17.8.11-bootstrapper (17.8.11-debian9.0.build1708190409.21)
WARNING:Skip fixing 'psa-pear': Cannot find deb-archive for package psa-pear (1.10.5-20180124.debian9.0.18012417)
WARNING:Skip fixing 'sw-engine-cli-2.24': Cannot find deb-archive for package sw-engine-cli-2.24 (2.24.13-debian.9.190731.1634)
# apt download psa-pear
E: Can't find a source to download version '1.10.5-20180124.debian9.0.18012417' of 'psa-pear:amd64'
Hello Gjimi
As I can see, you've created a support request already. Please, expect an update there.
Such issues usually require additional investigation.
