- Plesk
How to upgrade Plesk to Obsidian?
There are two ways to upgrade Plesk Obsidian:
An in-place upgrade is performed within one server environment. To perform an in-place upgrade:
OS should be supported by its vendor and Plesk
Installed Plesk version should support upgrade to Plesk Obsidian. The supported versions are:
- Plesk Onyx 17.0
- Plesk Onyx 17.5
- Plesk Onyx 17.8
If requirements are met, proceed with the upgrade using the method from this article.
If an earlier version is installed you can either upgrade to Plesk Onyx first if the installed version supports the upgrade to Plesk Onyx path, or Upgrade by transfer (Below).
Upgrade by transfer it is the process of upgrading by moving the current environment to the server with Plesk Obsidian installed. To do so:
- OS should be supported by its vendor and Plesk
- Currently installed Plesk version should support migration to Plesk Obsidian. Currently Plesk for Linux and Windows 8.6 and later are supported
Proceed with the steps from this article to migrate your server to Plesk Obsidian.
17 comments
Current version: Verzió 17.8.11 #67
plesk installer upgrade PLESK_18_0_18
Exception: Failed to solve dependencies:
plesk-dovecot-imap-driver-18.0-2.centos.7+p18.0.18.0+t190822.1506.x86_64 requires plesk-dovecot >= 2.3.6
plesk-dovecot-imap-driver-18.0-2.centos.7+p18.0.18.0+t190822.1506.x86_64 requires plesk-dovecot-pigeonhole >= 0.5.6
ERROR: The Yum utility failed to install the required packages.
Attention! Your software might be inoperable.
Visit https://support.plesk.com/ to search for a solution.
exit status 1
installed dovecot version:
plesk-dovecot 2.3.7.2-centos7.19090321 (PLESK_17_8_11-extras)
plesk-dovecot-core 2.3.7.2-centos7.19090321 (PLESK_17_8_11-extras)
plesk-dovecot-imap-driver 17.8.11-cos7.build1708190903.21 (PLESK_17_8_11-extras)
plesk-dovecot-pigeonhole 0.5.7.2-centos7.19090312 (PLESK_17_8_11-extras)
Hello,
I expected as part of the upgrade that curl and libcurl would also be updated, but this does not appear to be the case:
# rpm -q curl libcurl
curl-7.29.0-54.el7.x86_64
libcurl-7.29.0-54.el7.x86_64
According to the change log the version of libcurl on Obsidian is 7.63.0. How can I upgrade this? It is required in order to achieve full compatibility with a software package I am using.
Thanks
Hello Jászay,
Please submit a ticket to Plesk Support https://support.plesk.com/hc/en-us/requests/new to investigate the issue further.
Hello @Jef,
> Hello, is there a way to upgrade a Plesk server offline?
By design, this is not possible, upgrades are done online if you are talking about In-place upgrades.
For upgrades by transfer only connectivity between old and new Plesk servers is required.
> Or to keep the server off-network and only allow Plesk to communicate with the internet and install the latest Plesk?
This is a possible scenario. You may disable Plesk automatic updates and connect the server to the internet only when required and install required updates/upgrades.
Hi Jeroen Swets,
Ubuntu 14.04 is no longer supported OS for Plesk as per Plesk lifecycle policy https://www.plesk.com/lifecycle-policy/. In this case, a migration to a supported OS version is highly recommended in order to keep your Plesk server up-to-date.
How can I downgrade Plesk Obsidian to Plesk WebHost?
Hi @Ivan,
The OS is CentOS 7.
Thank you.
The upgrade checker doesn't seem to have an Obsidian version on http://autoinstall.plesk.com Is there one elsewhere?
Hello @Tara,
Let me know what's the exact issue you have?
According to my tests, the installer takes Plesk Obsidian packages from http://autoinstall.plesk.com/pool/PSA_18.0.*.
In case Plesk 18 isn't displayed for you as an option for the upgrade, make sure you have Plesk 17.8 installed because this is a prerequisite for Plesk Obsidian.
Also, make sure your server satisfies Software requirements: https://docs.plesk.com/release-notes/obsidian/software-requirements/
Hello @Khalequzzaman,
Probably, you've meant a downgrade to Plesk Onyx because WebHost is an edition of Plesk license: https://www.plesk.com/editions/
The scenario of Plesk downgrade is unsupported: https://support.plesk.com/hc/en-us/articles/213955885-Is-it-possible-to-downgrade-Plesk-or-roll-back-Plesk-updates-
Hello @Charles,
Thank you, I've reproduced this:
curl-7.29.0-46.el7.x86_64
libcurl-7.29.0-46.el7.x86_64
plesk -v
Product version: Plesk Obsidian 18.0.19
Build date: 2019/10/02 12:00
OS version: CentOS 7.5.1804
I'll clarify the reason will add this information here.
@Charles, I've clarified this, Packages were updated for Plesk installer binary itself so that it uses more modern version.
The curl installed on the server is provided by OS vendor.
You may trying upgrading it using similar method as, for example, here: https://talk.plesk.com/threads/plesk-backup-manager-problem-with-ftps-and-curl.345484/#post-836892
The correct link to Pre-upgrade checker for Obsidian is http://autoinstall.plesk.com/pool/PSA_18.0.20_1312/examiners/panel_preupgrade_checker.php
The upgrade process itself is fine and I was able to upgrade without issue.
It's just in the instructions above, under Advanced requirements, it says:
5. Download and run the latest pre-upgrade checker. If a problem is found, it is reported as a warning in the final report. The log file will have a full description of the issue with a link to a helpful KB article. Apply the solutions, then re-run the pre-upgrade checker until no warnings are reported or only non-critical issues (such as business logic warnings) are left.
You get the pre-upgrade checker from http://autoinstall.plesk.com/<Plesk_version>/examiners/panel_preupgrade_checker.php where <Plesk_version> is the desired version of Plesk you are willing to upgrade to. Trouble is the most recent version there is PSA_17.8.11. So while the instructions suggest running the pre-ugrade checker prior to upgrading to Obsidian, there is no pre-upgrade checker for Obsidian.
Hello @Charles,
Could you, please, provide the OS, where Plesk is installed?
I will need it to check on a test server.
I have tried everything to upgrade from onyx to obsidian on my VPS with Ubuntu 14.04.6 LTS and PLESK 17.8.11 to no avail.
The plesk upgrade does not appear in upgrade GUI interface.
Also when trying the CLI option I get the following options
I also have followed the tips here: https://talk.plesk.com/threads/in-place-upgrade-to-obsidian.353260/ But when trying plesk installer upgrade PLESK_18_0_31 (highest version avaiable) I get the message ERROR: There is no release with ID 'PLESK_18_0_31' of product 'plesk' at the installation source. But it -is- available (see image).
What to do?
