How to create autologin using an API request in Plesk?
Note: This article may require additional administrative knowledge to apply. If any help required, contact server’s administrator or hosting support.
1. Log in to Plesk server via SSH or a Linux workstation.
2. Create an XML file with the following content (in this example it will be named
request.xml
CONFIG_TEXT: <?xml version='1.0'?>
<packet version="1.6.3.5">
<server>
<create_session>
<login>TEST_USER</login>
<data>
<!-- Base64-encoded IP address of client, who logs into Plesk -->
<user_ip>MTkyLjE2OC4zNC4xOTI=</user_ip>
<!-- Base64-encoded hostname of computer from which the request is sent -->
<source_server>d3BiLXNpdGUudGxk</source_server>
</data>
</create_session>
</server>
</packet>
Session token will be created for the user identified by login.
3. Send created XML file to Plesk using
curl
# curl -kLi -H "Content-Type: text/xml" -H "HTTP_AUTH_LOGIN: admin" -H "HTTP_AUTH_PASSWD: PASSWORD" -H "HTTP_PRETTY_PRINT: TRUE" -d @request.xml https://<server-hostname-or-ip>:8443/enterprise/control/agent.php
NOTE : Only '
admin
' user is able to create session token for clients/resellers logins.
Response will look like the following:
CONFIG_TEXT: <?xml version="1.0" encoding="UTF-8"?>
<packet version="1.6.3.3">
<server>
<create_session>
<result>
<status>ok</status>
<id>ede520d0fc93ae7aa0524076d631fba2</id>
</result>
</create_session>
</server>
</packet>
Value of
id
tag will contain session token. In this example, '
Now, the script can redirect user’s browser to
rsession_init.php
and user will be logged in to Control Panel.
4. Login to Plesk using the session token:
For Linux:
CONFIG_TEXT: https://<server-hostname-or-ip>:8443/enterprise/rsession_init.php?PHPSESSID=ede520d0fc93ae7aa0524076d631fba2&success_redirect_url=<success_redirect_url>
For Windows:
CONFIG_TEXT: https://<server-hostname-or-ip>:8443/enterprise/rsession_init.php?PLESKSESSID=ede520d0fc93ae7aa0524076d631fba2
Here is the list of options:
PHPSESSID
(Linux only) - session token. -
PLESKSESSID
(Windows only) - session token. -
(optional) - URL where browser will be redirected after successful login procedure. -
failure_redirect_url
(optional) - URL where browser will be redirected after failure login attempt. Also this parameter will be used as logout URL. -
no_frames
(optional, deprecated) - show admin panel without frames -
locale_id
(optional) - locale name (e.g. de-DE)
Additional information is available in XML API Guide
2 comments
Since I needed a bit to make this work:
Apparently you have to check that IP addresses are allowed to change during Plesk sessions.
@Franz,
Thank you for posting, it might help someone else!
