High CPU load by IIS process
2 comments
    Yonahs
    I get the email from my plesk server alerting me to High IIS CPU Usage, but the email does not tell me which Pool is triggering the email. By the time I go to the server, the CPU usage has dropped back down.
    Is there any way to edit the email to give me that info?
    Robert Asilbekov
    @Yonahs  High IIS CPU usage might be caused by several application pools, whilst the CPU usage by each of them separately will be normal and will not trigger the alert. However, you may request this functionality to be implemented in Plesk and take part in our product improvement by referring to the following link: https://plesk.uservoice.com/forums/184549-feature-suggestions
