Watchdog activation issue: executable does not exist /bin/systemctl
Created:
2016-11-16 13:16:03 UTC
Modified:
2017-08-08 13:38:09 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
Error while activating Watchdog extension:
Fehler: Unable to process /opt/psa/etc/modules/watchdog/monitrc.tpl configuration file:
/opt/psa/var/modules/watchdog/data/monitrc.chk:19: Error: the executable does not exist '/bin/systemctl'
/opt/psa/var/modules/watchdog/data/monitrc.chk:20: Error: the executable does not exist '/bin/systemctl'
systemctl is not installed on the server.
The task is an administrative task which is out of scope of Odin technical support. .
Please contact the server administrator regarding the systemctl utility issue.Once the issue with the command systemctl is resolved, the Watchdog extension will work in Plesk.
