Log rotation doesn't work on a daily basis: error creating output file
Created:
2016-11-16 13:15:26 UTC
Modified:
2017-04-24 11:21:11 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
Logs are not being rotated on daily basis. Running logrotate utility fails with the following error:
# /usr/local/psa/logrotate/sbin/logrotate -v -f /usr/local/psa/etc/logrotate.conf
copying /var/www/vhosts/system/example.com/logs/error_log to /var/www/vhosts/system/example.com/logs/error_log.1
error: error creating output file /var/www/vhosts/system/example.com/logs/error_log.1: File exists
Corrupted files due to unexpected interruption of logrotate process by server restart or filesystem issues.
Remove corrupted file /var/www/vhosts/system/example.com/logs/error_log.1
