Webmail not loading after a wildcard subdomain is created
Created:
2016-11-16 13:14:56 UTC
Modified:
2017-08-16 16:40:04 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
After creating a wildcard subdomain for a domain, webmail.domain.tld does not load properly.
When searching for a virtual server by name, if name matches more than one of the specified variants, e.g. both wildcard name and regular expression match, the first matching variant will be chosen, in the following order of precedence:
  • exact name
  • longest wildcard name starting with an asterisk, e.g. “*.domain.tld”
  • longest wildcard name ending with an asterisk, e.g. “mail.*”
  • first matching regular expression (in order of appearance in a configuration file)
Please refer to Nginx server names .
It is software issue PPPM-1316 , which is fixed in Plesk 12.
Upgrade to the latest Plesk version.
Workaround
Define exact ' server_name ' for webmail subdomains in custom hosting templates:
  1. Create necessary directories and copy the template files:
    # mkdir /etc/nginx/plesk.conf.d/webmail
    # mkdir /usr/local/psa/admin/conf/templates/custom/
    # cp /usr/local/psa/admin/conf/templates/default/domain/nginxDomainVirtualHost.php /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php
    # cp /usr/local/psa/admin/conf/templates/default/nginxWebmailPartial.php /usr/local/psa/admin/conf/templates/custom/nginxWebmailPartial.php
  2. Modify ' /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php ' and ' /usr/local/psa/admin/conf/templates/custom/nginxWebmailPartial.php ' to look as the following:
    # cat /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php | grep -n5 file_put
    server_name ipv4.<?php echo $VAR->domain->asciiName ?>;
    <?php endif ?>
    <?php endif ?>
    <?php
    if (0 == substr_count($VAR->domain->asciiName, '*')) {
    file_put_contents('/etc/nginx/plesk.conf.d/webmail/' . $VAR->domain->asciiName . '.conf','server_name webmail.' . $VAR->domain->asciiName . ';' );
    <?php if ($VAR->domain->webAliases): ?>
    # aliases
    <?php foreach ($VAR->domain->webAliases as $alias): ?>
    # cat /usr/local/psa/admin/conf/templates/custom/nginxWebmailPartial.php | grep -n5 include
    <?php /** @var Template_VariableAccessor $VAR */ ?>
    <?php foreach ($VAR->server->ipAddresses->all as $ipAddress): ?>
    server {
    listen <?php echo $ipAddress->escapedAddress . ':' . $OPT['frontendPort'] . ($OPT['ssl'] ? ' ssl' : '') ?>;
    server_name webmail.* roundcube.webmail.* horde.webmail.* atmail.webmail.*;
    include /etc/nginx/plesk.conf.d/webmail/*.conf;
    <?php if ($OPT['ssl']): ?>
    <?php $sslCertificate = $ipAddress->sslCertificate; ?>
    <?php if ($sslCertificate->ce): ?>
    ssl_certificate <?php echo $sslCertificate->ceFilePath ?>;
    ssl_certificate_key <?php echo $sslCertificate->ceFilePath ?>;
If the above steps do not work, then check the webmail config path and include it's exact path into /usr/local/psa/admin/conf/templates/custom/nginxWebmailPartial.php :
server {
After the steps above are done, rebuild web configuration with httpdmng utility and disable/enable nginx service:
# /usr/local/psa/admin/sbin/httpdmng --reconfigure-all
# /usr/local/psa/admin/bin/nginxmng -d
# /usr/local/psa/admin/bin/nginxmng -e
