Plesk installation is listed as Failed on Odin Business Automation Standard side
Created:
2016-11-16 13:14:38 UTC
Modified:
2017-04-24 11:42:01 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
Plesk installation is listed as Failed on Odin Business Automation Standard side. But Plesk has been installed successfully on a container:
  • no errors are found in Plesk installation logs
  • Plesk is accessible at https://10.10.10.10:8443
  • running the following command shows that Plesk is installed:
    # plesk installer
    (*) Plesk 12.0.18 (Stable) (currently installed)
Plesk was installed not through Odin Business Automation Standard
To reflect valid data on Odin Business Automation Standard side, contact Odin support directly.
