.htaccess files are ignored and do not work
Created:
2016-11-16 13:14:33 UTC
Modified:
2017-08-16 13:14:46 UTC
6
Have more questions?
Submit a request
  • Plesk for Linux
The rules defined in .htaccess files are ignored.
.htaccess files support is not enabled.
To enable .htaccess files support, create *.conf file in /etc/httpd/conf.d/ with the following content:
AccessFileName .htaccess
<Directory "/var/www/vhosts">
Options +All
AllowOverride All
Order allow,deny
Allow from all
</Directory>
Note: The configuration above is applicable for Apache 2.2. For Apache 2.4 Options +All should be replaced with Options All
Then, restart Apache:
# service httpd restart
Please note that in Debian and Ubuntu the service is named "apache2" instead of "httpd" and the path is /etc/apache2/conf.d/ , instead of /etc/httpd/conf.d/ .
10 Comments
  • 0
    Avatar
    Gerasimos Perentidis
    The fix does not work.
    Also the article is vague.
    **** create *.conf file in /etc/httpd/conf.d/ ****
    What is   "  *.conf  "   ???
    What is the correct name for the file ?
  • 0
    Avatar
    Vitaly Zhidkov
    @Gerasimos, you can give any name to this file. For example "enablehtaccess.conf"
  • 0
    Avatar
    Cihan
    I am getting this error when I want to save the file
    [ Error writing /etc/httpd/conf.d/zz010_psa_httpd.conf: No such file or direct ]
  • 0
    Avatar
    Bulat Tsydenov
    @Cihan, you should not touch this file, it is generated by Plesk automatically. In order to regenerate it, you can run `plesk sbin httpdmng --reconfigure-server`
  • 0
    Avatar
    Cihan
    @Bulat I didn't touch it, it doesn't exist. I read in this document (in German) to do it like that: https://kb.plesk.com/de/124
    Also it doesn't matter how I name the file, always getting the error No such file or direct
  • 0
    Avatar
    Bulat Tsydenov
    @Cihan, it seems you don't have `/etc/httpd/conf.d/` folder. Maybe you are using Ubuntu/Debian? In this case, the path should be /etc/apache2/conf.d/
  • 0
    Avatar
    Alexandros Boukouris
    Not working in Plesk Onyx.
    Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
    ● httpd.service - The Apache HTTP Server
    Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
    Active: failed (Result: exit-code) since Tue 2017-05-02 17:26:50 EEST; 23s ago
    Docs: man:httpd(8)
    man:apachectl(8)
    Process: 22295 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=1/FAILURE)
    Process: 22293 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
    Main PID: 22293 (code=exited, status=1/FAILURE)
    May 02 17:26:50 systemd[1]: Starting The Apache HTTP Server...
    May 02 17:26:50 httpd[22293]: AH00526: Syntax error on line 4 of /etc/httpd/conf.d/enablehtaccess.conf:
    May 02 17:26:50 httpd[22293]: You may not use 'Options +All' or 'Options -All'.
    May 02 17:26:50 systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
    May 02 17:26:50 kill[22295]: kill: cannot find process ""
    May 02 17:26:50 systemd[1]: httpd.service: control process exited, code=exited status=1
    May 02 17:26:50 systemd[1]: Failed to start The Apache HTTP Server.
    May 02 17:26:50 systemd[1]: Unit httpd.service entered failed state.
    May 02 17:26:50 systemd[1]: httpd.service failed.
    Obviously the "Options +All" is not accepted by httpd. Is it newer version and needs something else?
    Thanks!
    Edited by Alexandros Boukouris
  • 0
    Avatar
    Nikolay Zhmuk
    2Alexandros, It depends on version of Apache. For Apache 2.4 "Options All" should be used. The article has been updated. Thank you for the input.
  • 1
    Avatar
    Johnny Ambrosio
    If one would want a specific domain only to have this setting would the syntax just be...
    <Directory "/var/www/vhosts/domain.com">
    would that work?
    Thanks in advance for help...
  • 0
    Avatar
    Vitaly Zhidkov
    @Johnny, yes, it should work
