- Plesk Onyx for Linux
- Plesk Onyx for Windows
Unable to see available applications in Plesk when accessing Domains > example.com > Applications > Available Applications. Instead of the applications list it shows:
CONFIG_TEXT: Your search did not match any apps.
There is no available applications to install from the Application Vault in Subscriptions > example.com > Application:
Option Provide only applications that I select enabled for the corresponding service plan or for customized subscription/webspace, however there is not any application added to the list of available applications.
Browse to one of the pages:
Service Plans > service plan name > Applications tab
Subscriptions > example.com > Customize > Applications tab:
Add the necessary applications to the list Selected:
Otherwise, disable option Provide only applications that I select, if it was checked by accident.
