ERROR: Call to undefined method Zend_Validate_Abstract::hasDefaultTranslator()
Created:
2016-11-16 13:13:26 UTC
Modified:
2017-05-11 09:49:42 UTC
Have more questions?
Submit a request
  • Plesk for Windows
Plesk Panel displays the below error:
Root cause
Some Plesk Panel binaries and .dll files were not properly updated during the upgrade process.
  1. Files in the following directories should be checked: %plesk_bin%, %plesk_cli%, %plesk_dir%\admin\htdocs, %plesk_dir%\admin\plib
    To verify files versions, you may use the Windows explorer with the "File version" field enabled,:
    Enable the field:
    Examine files versions:
  2. Files with older Plesk version could be replaced by the ones, extracted from the MSI packages, as per this article:
Plesk MSI packages are usually stored at 'C:\\ParallelsInstaler' or 'C:\\Program Files (x86)\\Parallels\\Install' . The following packages contain the binary files that might be needed: plesk.msi, plesk-service-node-utilities.msi,plesk-engine.msi
