Unable to access Plesk: /usr/local/psa/admin/logs/panel.log cannot be opened with mode "a"
9 comments
    Clintvee
    I am getting these exact symptoms. Specifically the third error on the Plesk dashboard.
    I do appreciate the time taken to write these steps.
    However, these steps did not solve the issue for me personally.
    Alexandr Tumanov
    @Clintvee, hi, what is your Plesk version?
    Clintvee
    It is 12.0.18
    Alexandr Tumanov
    @Clintvee, did you restart Plesk services?
    Please show me an output of these commands:
    # ls -la /var/log/plesk/panel.log
    # ls -ld /var/log
    Clintvee
    -rw-r----- 1 psaadm root 0 Apr 11 13:27 /var/log/plesk/panel.log
    drwx------ 5 root root 4096 Apr 11 13:56 /var/log
    Andy Koopmann
    hi, can you help me?
    fooked my server by changing all users and groops in /var/
    looks like this now,
    [root@ms142 var]# ls -la
    insgesamt 140
    drwxr-xr-x. 26 root root 4096 11. Okt 2012 .
    dr-xr-xr-x. 26 root root 4096 7. Apr 14:22 ..
    drwxr-xr-x. 2 root root 4096 22. Mär 2017 account
    drwxr-xr-x. 18 root root 4096 6. Mär 10:48 cache
    drwxr-xr-x. 2 psaadm root 4096 9. Feb 14:00 crash
    drwxr-xr-x. 2 psaadm root 4096 22. Nov 2013 cvs
    drwxr-xr-x. 4 psaadm root 4096 8. Okt 2012 db
    drwxr-xr-x. 3 root root 4096 23. Sep 2011 empty
    drwxr-xr-x. 2 root root 4096 23. Sep 2011 games
    drwxr-xr-x. 44 psaadm root 4096 11. Apr 04:19 lib
    drwxr-xr-x. 2 psaadm root 4096 23. Sep 2011 local
    drwxrwxr-x. 9 root lock 4096 11. Apr 16:04 lock
    drwxr-xr-x. 23 psaadm root 4096 10. Apr 04:05 log
    drwx------. 2 root root 16384 8. Okt 2012 lost+found
    lrwxrwxrwx 1 root root 10 8. Okt 2012 mail -> spool/mail
    drwxr-x--- 6 psaadm root 4096 26. Jan 12:40 named
    drwxr-xr-x. 2 psaadm root 4096 23. Sep 2011 nis
    drwxr-xr-x. 2 root root 4096 23. Sep 2011 opt
    drwxr-xr-x 2 psaadm root 4096 8. Okt 2012 parallels
    drwxr-xr-x. 2 root root 4096 23. Sep 2011 preserve
    -rw-rw-r-- 1 root root 12608 28. Okt 2012 proftpd.delay
    drwxr-xr-x 8 psaadm root 4096 29. Jan 12:06 qmail
    drwxr-xr-x. 32 psaadm root 4096 11. Apr 16:04 run
    drwxr-xr-x. 13 root root 4096 8. Okt 2012 spool
    drwxrwxrwt. 2 root root 12288 11. Apr 04:17 tmp
    drwx------ 3 root bin 4096 7. Apr 14:23 webmin
    drwxr-xr-x 9 root root 4096 19. Okt 18:44 www
    drwxr-xr-x. 3 psaadm root 4096 8. Okt 2012 yp
    used the comand sudo chown -R on the folder
    so no access to plesk and the websites
    Alexandr Tumanov
    @Clintvee, permissions on /var/log are incorrect. Do the following and restart Plesk services:
    # chmod 0755 /var/log/
    Alexandr Tumanov
    @Andy, in this case, I can suggest only comparing with a working server and changing the permissions manually. It also depends on how much permissions were changed.
    Clintvee
    The support team for our hosting company ended up resolving it in the end.
    I checked the permissions of the /var/log/ file and can see they are now
    drwxr-xr-x 6 root root 4096 Apr 12 03:20 log
    Thanks for your support!
