The word Grenze is written with small first letter in resource usage notifications in German language
Created:
2016-11-16 13:11:09 UTC
Modified:
2017-08-16 16:34:08 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
The variable is used in notification:
 "Speicherplatz:    10 GB grenze / 12751.2 MB (125%) verwendet / 0 MB (0%) verbleibend"
In German it is required to write „Grenze“ instead of „grenze“.
This is a software issue with internal ID #PPPM-4332 . The fix will be included in further Plesk updates.
Replace /usr/local/psa/admin/plib/builders/PlainTableBuilder.php file with fixed one
It removes automatic transformation to lowercase for all 3 fields (grenze, verwendet, verbleibend)
If it is not required to change last two fields:
Replace /usr/local/psa/admin/plib/Limits/Plesk/Helper/Table.php file with fixed one
