It is not possible to allow API XML request from certain subnet using CIDR ranges
Created:
2016-11-16 13:08:56 UTC
Modified:
2017-04-24 11:56:20 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
As it is described in Plesk Administrator's Guide It is available to allow connections only from specific IP addresses via API XML requests by adding the following lines to panel.ini
[api]
allowedIPs = <IP_addresses>
However, such parameter does not support CIDR ranges.
This is internal issue #PPPM-4394
Workaround
Specify each IP address from subnet one by one.
