Php-sites does not work
Created:
2016-11-16 13:08:21 UTC
Modified:
2017-04-24 11:23:54 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
  • Php-sites does not work. There is nothing shown in the website access log and error log.
  • Autoinstaller also fails with:
    PHP_5.6.21/php56-5.6.21-cos7-x86_64.plesk12.inf3: Error: Empty reply from server, retry...
Network issues.
  1. Place the affected website in server hosts:
    # cat /etc/hosts
    1.1.1.1 example.com
where 1.1.1.1 is IP of subscription.
  1. Check if the website is available from the localhost:
    # curl -vk http://example.com
if the output shows something like:
    <HTML><HEAD><meta http-equiv="content-type" content="text/html;charset=utf-8">
<TITLE>302 Moved</TITLE></HEAD><BODY>
<H1>302 Moved</H1>
then check that ports 80 , 443 are not filtered with system firewall and network firewall. Also make sure the connection is stable.
