Fail2Ban does not block failed login attempts via SSH key-based
Created:
2016-11-16 13:08:18 UTC
Modified:
2017-04-24 11:56:41 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  1. SSH is configured to use key-based authentication
  2. ssh jail is activated in Fail2Ban
  3. Fail2Ban detects failed login attempts in /var/log/secure
  4. Fail2Ban does not block access to Plesk via ssh after detecting required number of failed login attempts
Fail2Ban does not block access to Plesk for ssh key-based authentication. ssh jail is applied to password-based authentication only.
It is not required to block failed login attempts via ssh with key-based authentication as there is no practical way to brute-force the key. Any login attempts will fail anyway because they won't have the matching key.
Fail2Ban will perfectly block IPv4 brute-force attempts via ssh when password authorization is required.
