Cache expiration header in additional Nginx directives does not get applied
23 comments
    Unknown User
    What is the exact change because the current configuration is for a domain PHP handler is set as "FPM application served by Apache". And also the workaround states the same thing:
    Change PHP handler to "FPM application served by Apache" in Domains > example.com > Hosting settings .
    Lev Iurev
    Hi @gli Pançi, do you mean that handler is set to "FPM application served by Apache" and cache expiration is enabled in nginx  but cache expiration headers are not returned by server?
    David McLaughlin
    I have FPM application served by Apache and nginx in proxy mode.
    Despite the change I never see the cache-control header.
    Anna Morozyuk
    Hi @David,
    If expire headers are not working with Apache, another reason might be involved. Please submit request to a support in order to investigate it thoroughly: https://support.plesk.com/hc/en-us/articles/213608509-How-to-submit-a-request-to-Plesk-support-
  • 0
    Nikita Nikushkin
    Hi @Matthias,
    Thank you for the provided way!
    I added a link to this article in the "Additional information" section in order to help others, who have the applied Hotlink protection security measure in WordPress as you, to resolve the issue
    Mikhail K
    Looks like it works fine once "Hotlink protection" is disabled. Spent about 1 hour trying to fix it on a new domain - didn't suspect Plesk initated update. Just in case, I got 3.6.1-1603 of WP Toolkit and Version 17.8.11 Update #40 of Plesk.
    Alexandr Redikultsev
    Hi @Mikhail Krivoshein,
    You hit another bug here that is documented on the following link: https://support.plesk.com/hc/en-us/articles/360014674853-Additional-nginx-directives-Leverage-browser-caching-are-ignored-for-WordPress-website
    its still not entirely fixed though, but will be fixed soon!
    Rafal Kukla
    Hey guys,
    Not sure if the fix has been released yet,
    I've got fresh version of Plesk, fully updated, and expiry headers are not being applied, not only in WordPress, but in any site, including static HTML.
    If you could give me an update.
    Thanks
    Ivan Postnikov
    Hello @Rafal,
    Indeed, it is not fixed yet. It is planned to be fixed in the next major Plesk release.
    For now, please, use the workaround specified in this article.
    Rafal Kukla
    I'm afraid this isn't possible, entire Hosting environment is configured for NGINX.
    Any ETA on the next Plesk release?
    1
    Ivan Postnikov
    @Rafal,
    Right now there is no precise ETA for the release.
    After the fix will be ready this article will be updated with the corresponding information.
    Additionally, the description of releases and fixed issues may be found here: https://docs.plesk.com/release-notes/onyx/change-log/
    Tim Hosking
    Seriously, when is this going to be fixed? Serving the site from Apache behind nginx is not an option as we have quite a number of production sites being served directly by nginx that have been heavily optimised and tested using pagespeed. The work involved in reconfiguring and re-testing them to run Apache behind nginx is unthinkable.
    1
    Anton Maslov
    Hello Tim, we don't have ETA at this moment.
    1
    Adrian
    Anton Maslov Ivan Postnikov we desperately need this bug fixed, as it has a detrimental impact on the website performance scores. This bug has been going on for nearly 1 year now, why does it take so long to fix it for us using nginx?
    1
    Anton Maslov
    There are workarounds by using Apache as well as alternative Wordpress plugins/solutions to use cache, thus priority for this bug is low. We don't expect this bug to be fixed in nearest time.
    Betafer
    ............. No words !
    2
    Emilio
    We need a solution for this.
    Any ETA on the next Plesk release with a solution for this?
    Alphamega
    PHP handler is FPM application served by Apache
    But still expire settings are ignored! Even when set in apache config or .htaccess
    We run NGINX  as proxy. Also the link "Additional nginx directives/Leverage browser caching are ignored for WordPress website" is not pointing to any article!
    Alexey Lapshin
    Hello, @Sysadmin
    If after applying the workaround the issue remains - please submit a ticket to us: https://support.plesk.com/hc/en-us/articles/213608509-How-to-submit-a-request-to-Plesk-support-
    The link to non-existing article was removed, thank you for pointing our attention to that!
    Alexey Lapshin
    Hello, @Emilio
    Currently we have no ETA for fixing this issue. Please use the workaround described in the article.
    Mickael Kerenterff
    Hello, the fix is ​​not working. Moreover, it is impossible to send you a message via the support because I have a license from OVH in France. How to do ? Thank you
    Yulia Plokhotnikova
    @Mickael Kerenterff
    All support options are described here:
    Shortly, if a license was bought from OVH, OVH should provide support for Plesk. Please contact them for assistance. If needed, they will contact us directly on your behalf.
    If they cannot assist you or you would like to receive support from Plesk directly with OVH license, consider subscribing to the Support Subscription:
    https://support.plesk.com/hc/en-us/articles/213953025
