- Plesk 12.5 for Linux
- Plesk Onyx for Linux
- Plesk Onyx for Windows
DNS forwarding does not work for a website and the following error appears:
404 Server Not Found
DNS name is not resolved to Plesk IP address by public DNS servers:
# ping example.com
PING example.com (203.0.113.2) 56(84) bytes of data.
64 bytes from external.tld (203.0.113.2): icmp_seq=1 ttl=54 time=233 ms
64 bytes from external.tld (203.0.113.2): icmp_seq=2 ttl=54 time=233 ms
64 bytes from external.tld (203.0.113.2): icmp_seq=3 ttl=54 time=233 ms
DNS name is resolved to Plesk IP address by public Plesk DNS server:
# dig @203.0.113.5 +short example.com
203.0.113.5
Domain name is resolved to incorrect IP address by public DNS servers. Misconfiguration on domain registrar side.
Contact domain registrar company where the domain name was purchased to set the correct IP address on the DNS zone. Name server record ns.example.com should be associated with the IP address that was set in Plesk > Domains > example.com > Websites & Settings.
After the configuration changes are made on the domain registrar's side, it takes up to 48 hours for them to get propagated (applied).
As a temporary workaround for the clients, the correct "IP address - domain name" association can be added to
%systemroot%\system32\drivers\etc\hosts
file on their workstations, for example:
203.0.113.5 example.com
Note: the actual domain name and IP addresses should be used when applying the instructions.
