Plesk upgrade failed: Unable to read Control Panel configuration file
Created:
2016-11-16 13:06:41 UTC
Modified:
2017-08-16 18:31:05 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Windows
  • Plesk 12.0 for Windows
  • Plesk 12.5 for Windows
The following error is shown during or after Plesk upgrade:
Unable to read Control Panel configuration file: date_default_timezone_get(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Australia/Melbourne' for '10.0/no DST' instead
OR
Failed loading C:\Program Files (x86)\Parallels\Plesk\admin\modules\ioncube_loader_win_5.4.dll
Zend OPcache requires Zend Engine API version 220100525.
The Zend Engine API version 220121212 which is installed, is newer.
Contact Zend Technologies at http://www.zend.com/ for a later version of Zend OPcache.
Also, this warning can be found in %plesk_dir%\admin\logs\php_eror_log :
PHP Warning:  file(/etc/psa/psa.conf): failed to open stream: No such file or directory in C:\Program Files (x86)\Parallels\Plesk\admin\plib\Conf.php on line 26
Incorrect path to Plesk configuration file. Incorrect permissions.
  1. Make sure that the path to Plesk configuration file is correct in [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Parallels\Engine\Config] :
    "IniFilePath"="C:\Program Files (x86)\Parallels\Plesk\admin\conf"
Note: the configuration file path can be specific on different Plesk installations
  1. Run Plesk Reconfigurator > Repair Plesk Installation > Plesk File Security or simply %plesk_bin%\reconfigurator.exe to fix broken permissions
  2. Run Plesk upgrade once again:
     "%plesk_bin%\ai.exe" --console
