The value of
max_connections
changes to214
automatically after some time, although the value itself is defined inmy.cnf
:# grep -i 'max_connections' /etc/my.cnf
max_connections=2048# plesk db "SHOW GLOBAL VARIABLES LIKE 'max_connections' \G"
*************************** 1. row ***************************
Variable_name: max_connections
Value: 214 -
The value of
open_files_limit
is reset after system updates are installed. -
In the log file
/var/log/mysqld.log
the following records can be found:CONFIG_TEXT: [Warning] Changed limits: max_open_files: 1024 max_connections: 214 table_cache: 400
When restoring a MySQL backup, the following error is shown:
Warning: mysql "databasename"
Not all the data was backed up into [...]/databasename_1 successfully. mysqldump: Got error: 23: Out of resources when opening file '[...]' (Errcode: 24 - Too many open files) when using LOCK TABLES - Unable to export database in Plesk:
PLESK_ERROR: Unable to export a dump of databasename:
mysqldump: Got error: 1016: "Can't open file: './databasename/table.frm' (errno: 24)" when using LOCK TABLES
Default open_files_limit
for MySQL has been reached.
Connect to the server via SSH and adjust open_files_limit
for the MySQL service as below.
On systemd-based systems (RHEL/CentOS/CloudLunix 7 and above, Ubuntu 16.04 and above, Debian 8 and above)
Find out whether MySQL, or MariaDB service is used:
# systemctl list-unit-files | grep -E 'mysql|mariadb'
mariadb.service enabled -
Create an override for the service file from the previous step:
# systemctl edit mariadb.service
Note: In case
mysql.service
, ormysqld.service
was displayed on the previous step, replace "mariadb.service
" with it. -
Add the following content to the opened text editor and save the file:
CONFIG_TEXT: [Service]
LimitNOFILE=4096Note: Value might be increased if required, 4096 is only a suggested value.
Restart the MySQL/MariaDB server:
# systemctl restart mysql mysqld mariadb 2>/dev/null
On System V/Upstart systems (Ubuntu 14.04, RHEL/CentOS/CloudLinux 6)
Add the following lines in
/etc/security/limits.conf
:CONFIG_TEXT: mysql soft nofile 4096
mysql hard nofile 4096 -
Add the following to the end of file into
/etc/pam.d/common-session
:CONFIG_TEXT: session required pam_limits.so
/etc/pam.d/common-session-noninteractive
Add the following line in
/etc/mysql/my.cnf
and under the[mysqld]
section:CONFIG_TEXT: open_files_limit = 4096
Restart the MySQL service:
# service mysql restart
/etc/sysctl.conf
:CONFIG_TEXT: fs.file-max = 65536
Edit the file /
and add lines:CONFIG_TEXT: * soft nproc 40960
* hard nproc 40960
* soft nofile 40960
* hard nofile 40960 -
Edit the file
/etc/security/limits.d/90-nproc.conf
* hard nproc 40960
* soft nofile 40960
/etc/my.cnf
# service mariadb restart
3 comments
Ubuntu has moved from Upstart to Systemd from version 15.04 and no longer respects the limits in /etc/security/limits.conf for system services. These limits now apply only to user sessions.
The limits for the MySQL service are defined in the Systemd configuration file, which you should copy from its default location into /etc/systemd and then edit the copy.
sudo cp /lib/systemd/system/mysql.service /etc/systemd/system/
sudo vim /etc/systemd/system/mysql.service # or your editor of choice
Add the following lines to the bottom of the file:
LimitNOFILE=infinity
LimitMEMLOCK=infinity
You could also set a numeric limit, eg LimitNOFILE=4096
Now reload the Systemd configuration with:
sudo systemctl daemon-reload
Restart MySQL and it should now obey the max_connections directive.
Hello nisamudeen,
Thank you for your reply! A section regarding systemd systems was added accordingly.
Yes it work,after setting params in /etc/systemd/system/mysql.service ,this is for newer ubuntu versions
